Old 04-06-2009, 03:57 PM
hoopdaddy6's Avatar
hoopdaddy6 hoopdaddy6 is offline
Send a message via MSN to hoopdaddy6
Check engine light on 89 cherokee
This might be a dumb question, but I have consulted with the auto parts stores, chiltons, owners manual, and everywhere but I can't find a check engine light on my jeep. Perhaps the bulb is burned out, but where should the light be located? Owners manual doesn't even reference it once.
When I initially turn on the ignition it should come on, right? Or am I just crazy.
I know it should have a couple of codes, but nobody seems to know how to get at them.
Old 04-06-2009, 05:30 PM
Ros981500's Avatar
Ros981500 Ros981500 is offline
Re: Check engine light on 89 cherokee
Shine a Light on your gauges and you will see were it is located!!!!!!!!!!!!!!!!!!!
Old 04-09-2009, 01:00 PM
Saudade's Avatar
Saudade Saudade is offline
That's because you, in fact, don't have one. The Renix system does not store codes. There is a diagnostic connector in the engine bay but that's to read real time data, not stored data. You need a special scanner. Or you can troubleshoot the entire system using a pair of Volt/Ohm meters.
Search some more on Renix Sensor Diagnostics and you'll find lot's of worthwhile reading.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Old 04-09-2009, 05:16 PM
hoopdaddy6's Avatar
Thanks for the info, Saudade. I have been going crazy trying to figure out how to get some codes out of her. I will do some more research on the Renix Diagnostic System. If you have any links or anymore info that may help, that would be greatly appreciated.
Tags
bulb , check engine light , cherokee , jeep , obd
