| Off-Topic Talk about anything other than cars. |
Intake Upgrading
Would i be able to fit a 4" intake and run on a stock turbo? How about the evo 16g turbo? I just wanna know if i can fit a 4" intake from this site http://www.dsmparts.com/intake_pipes__dsm_2g.htm on my dsm. any info would be helpful.
"Cant you see that your smothering me, holding too tightly, afraid to loose control cause everything that you thought i would be, is falling apart..right in front of you....every step that i take is another mistake to you, and every second i waste is more then i can take" |
Re: Intake Upgrading
Remeber you are only as good as your most restrictive piece. That means you would have to upgrade your MAS to 4" if they make them. I know they make 3" and 3.5" and you would also need a Translator for the bigger MAS. I don't know if it will bolt to the stock turbo or not. The 2 3/4 from dejontool flows awesome, that is what I have with the K&N FIPK. I can hear the turbo spool, it sounds awesome.
The stock turbo inlet is either 2" or 2.5"
if you can get the 4" pipe to reduce down to that size and get the MAS to bolt up to it, then its possible |
i just got an injen and called it a day...
so whats the biggest i can get for an evo 16g?
PS: like my new ava? 3 minutes in photoshop
What isthe reson for wanting a 4" pipe? IF you plan to get a 4" inlet turbo in the future it makes sense, otherwise I wouldnt go over 3" See my website for how to make a home depot 3" or buy one. You will need a coupler that reduces down to the size of your turbo. A 4" rubber couplre will fit the 2g mas, a silicon type coupler may not. I Didnt check out that link, but try to buy a pipe that comes with all this BS, and made for the MAS you are running.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
