Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-06-2005, 10:50 PM
silverstrike silverstrike is offline
Question Stock to Performance Intake Upgrade
I have a 92 Plymouth Laser, same as talon/eclipse. The mass air flow sensor is inside the stock filter. I want to upgrade to performance intake but then what will I do with the sensor? It will not fit into the performance pipe and filter? I know about the resistor "chip" that can be plugged in, is that all I have to do? Please help me with the step by step intallation proccess so that I do not ruin my engine.
Thanks
Old 04-06-2005, 11:06 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Stock to Performance Intake Upgrade
the sensor thats in the airbox is not the MAF, its the Intake Air Temp Sensor. DO NOT use those resistors, they will just make your car run rich and get lousy gas mileage. Most intakes will have a hole for the IAT to plug into, but if not you can just zip-tie it near the filter inlet.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 04-06-2005, 11:25 PM
Thanks
Ok, so all i have to do is attach the new intake and not worry about the wires that would plug into the stock box? will it harm my car by not having these plugged in anywhere? Where is the Mass air flow sensor?
Old 04-07-2005, 05:50 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
your car wont idel right and yes its bad for you engine. I tried it dosent work and yes its the MAF in the stock filter I just bought this http://www.cosmoracing.com/productin...id=167&pid=554
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 04-07-2005, 06:13 PM
Re: Re: Stock to Performance Intake Upgrade
Yeah thats kinda what i figured, its not any small sensor, the thing is huge, thanks for the link. Have you seen the same filter kit for less than 55?
Thanks
Old 04-07-2005, 06:42 PM
nope that the only filter I have ever seen.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 04-10-2005, 05:47 PM
Whathits14 Whathits14 is offline
get a k&n fipk. Doesn't replace MAS, then build a cheap hardpipe, and do the honeycomb removal mod for better airflow. also, if you can get a used 2gmas for cheap, it flows a lot more than the 1g
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
