Old 01-10-2004, 04:29 PM
blade34609's Avatar
blade34609 blade34609 is offline
Timing Belt Tension?
Hi,
I already took my head off and replaced the head gasket.
Anyways, When i took the timing belt off I just marked it with white-out and put it back on. But how tight should the belt be?
I loosend the adjusting bolt to put it back on the cam.
Then I tightend it back up.
But the belt doesnt feel as tight as when I first had it on b4 i loosened it.
I find that by moving the afjusting pulley you acn loosen the belt but how do you get it tighter?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 01-10-2004, 08:09 PM
BullShifter's Avatar
Re: Timing Belt Tension?
http://www.binghamtonlife.com/manual...es/91-6-27.jpg - might need a new tensioner
Old 01-10-2004, 08:37 PM
91civicDXdude's Avatar
make sure that before you tighten the tensioner, turn the engine over manually about 1/4 turn, counter clockwise, judging by the cam sprocket's position.
Old 01-10-2004, 10:14 PM
blade34609's Avatar
Alright guys after an hour of messing wit the timing belt I got it to tighten.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
99 Villager Timing belt replacement celica92gt Villager 2 08-22-2010 11:32 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
91 Metro 3cyl Timing belt help. Timing belt tensioner?..... doug2060 Metro 4 06-17-2008 10:40 PM
Timing belt tension spring's purpose AFTER belt install? Allen McCready Camry/Camry Hybrid/Vista 2 11-26-2004 10:42 PM
