Go Back   Automotive Forums Car Chat > Ford > Contour
Old 07-16-2005, 10:52 AM
charliewensman charliewensman is offline
heater fan only works on high
my 98 2 liter heater fan doesn't work on the lower two settings, just on high. How can I fix this?
Old 07-16-2005, 11:26 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Discussed ad nauseum on contour.org.
http://www.contour.org/ubbthreads/sh...rue#Post872290
http://www.contour.org/ubbthreads/sh...rue#Post972477
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-19-2005, 01:13 PM
JimR's Avatar
JimR JimR is offline
Re: heater fan only works on high
you should check the switch in the dash. in my GL my high would not work because the high setting in the switch was mealted ez fix.
Old 08-10-2005, 09:54 PM
contourhater2 contourhater2 is offline
Re: Re: heater fan only works on high
That was another of the recalls for my 97. The lights in the radio quit working after the dealer replaced the heater switch.
Old 08-20-2005, 05:02 PM
oldspower_68 oldspower_68 is offline
It sounds like it needs a heater blower resistor. it is on the passanger side under the dash by the blower motor it has a 4 wire connector going to it. make sure the wiring isn't burnt either. very common problem
