Old 01-09-2004, 02:13 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
Window Fascia Removal
I have a 2 door 88 Grand Am, and i would like to remove the rear window fascia's to do some work on the body but not sure on how to do this, There are three screws holding it on behind the doors, but after you take them out the fascias do not become any looser. I'm afraid to pull on them too much since they are cracked pretty bad in several locations, any great force then they might just shatter. The drivers side rear fascia is loose along the top part of the window, but the way that they are designed I can't see down inside to tell what's going on. Does anyone know how to remove them or there are clips I should be looking out for.. etc. I know that the window fascias are the same from 85-91 2 door grand ams... so anyone with some info.... would be greatly appreciated!
Paul
Old 01-13-2004, 08:27 AM
boristheblade boristheblade is offline
Most window facias are held in with clips, if they are already pretty cracked, your best bet might be that of just going to your nearest Pick n Pull and getting new facias.
Old 01-13-2004, 04:55 PM
grfnkl's Avatar
Thank you, I will check and look for the clips that hold it in place. I am planning on replacing them but so far the yard I've gone to has only had 4 door models or two door models in worse condition then mine. I'll give it a try.
Window Tint Removal mustangman Mustang Talk 11 05-13-2004 04:38 PM
window trim removal cerealkiller696920 Explorer | Explorer Sport Trac 1 03-17-2004 09:50 PM
window handle remover paintball4me5698 Ranger | Courier 2 11-18-2003 04:47 PM
Window Tint Removed!! *pics* 90civicrider '88 - '91 Civic | CRX | Wagon | Shuttlee 15 10-05-2003 11:47 PM
Window Crank Removal and Replacement moleodonuts '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-09-2003 11:29 PM
