Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-09-2003, 09:18 PM
paintball4me5698 paintball4me5698 is offline
Question window handle remover
Does anyone know how to remove the window crank from my ford ranger? I have tried sooooo hard and i'm getting frustrated that i can't get it off to install my speakers. Please someone help me. ASAP
Old 11-10-2003, 08:59 PM
EVH5150 EVH5150 is offline
If it's like mine you have to remove the cover on the handle with a flathead screwdriver. after that, at the pivot area there is a torx screw that you have to remove, and the handle should pull right out. what kind of speakers are you installing. I recently blew mine.
Hope this helps. Good luck.
Old 11-18-2003, 04:47 PM
Perrycmc Perrycmc is offline
Most likely it is like all the other newer cars in the world, take your handle and pull it towards you between the crank and the doorpanel if you look behind it there is a little clip that looks like this
__
Pop it out with a Flathead screwdriver, but dont lose it because your crank wont stay back on without it. Pull the crank towards ya and your handle is off.
Window Handle Removal 03BlackBeast Silverado 0 06-03-2006 11:48 AM
how do I remove the window handle? kkwelcher General Discussion 3 01-12-2006 11:28 PM
2005 E250 Remove window handle there is no clip visible grk65 Econoline 0 01-12-2006 04:45 PM
window handle removal bBoYLXIX Accent | Verna 2 09-02-2004 04:38 PM
