Old 01-09-2004, 11:31 AM
Daedalus_ack Daedalus_ack is offline
Overly active trac control light...
I've a 2000 grand am with the 2.4 engine, auto ect. pretty much a plain jane of a car.
I have a problem with the traction control light coming on even when I'm on dry pavement. For instance I can back out of my parking space( it's all head-on parking at my apartment complex and the light will come on and at times the brakes will grab. The alignment is correct ,the air pressures are right, and the Dealer says it's a faulghty sensor.
Is this a common fault and is it someone can replace themselves?
Old 04-15-2004, 02:26 AM
JohnsonGA JohnsonGA is offline
Overactive traction control
Dude,
I had the same exact issue with my '99 Grand AM SE.
All you need to do is tighten the SWAY BAR END-LINK BUSHINGS.
This worked for me.
Old 04-15-2004, 09:12 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Overly active trac control light...
Or you could believe the dealers and have it fixed "properly". Did the dealer scan your computer to come up with that diagnosis?
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 04-15-2004, 12:21 PM
traction control
Actually,The dealer didn't scan my computor, they sugessted I check the bushings for proper tork, I found the end-links to be loose, now the only time my traction control light comes on is if the wheel are spinning due to snow or when I peel out.
Old 04-15-2004, 12:31 PM
Say does your low track light come on bumpy roads?
Old 04-15-2004, 12:42 PM
actually yes, basically whenever the tires loose grip with the ground
ABS and Traction Control Lights on after Jump start jbinramona Seville 5 05-11-2011 08:45 AM
ABS and Traction Control Lights on after Jump start jbinramona Seville 0 06-22-2010 10:11 AM
2001 Pontiac Grand AM ABS Light, Service Vehicle Soon Light and Trac Control OFF blueesheep9525 Grand AM 2 10-05-2006 08:10 AM
CK ENG, ABS & TRAC CONTROL LIGHTS ARE ON SURENOWINLIFE Aurora 1 10-28-2005 11:03 AM
2001 Solara Check engine and trac control light on jasjfarrell Solara 1 02-28-2005 02:11 AM
