Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 06-22-2010, 10:04 AM
jbinramona jbinramona is offline
ABS and Traction Control Lights on after Jump start
Jump started my '99 Seville SLS from under the hood. Let some factory installed smoke out from near the coils. Now I have some lights on the dash, ABS and Traction Control & two messages, Service Stability Sys & Service Steering Sys. Brake pedal seems a bit stiff and steering is a bit stiff. White smoke from exhaust when first started, but seems to drive okay. Any suggestions?
Thanks!
Jerry
Old 06-22-2010, 05:44 PM
maxwedge maxwedge is offline
A990 racer
Re: ABS and Traction Control Lights on after Jump start
You need a full scan to access the bcm anti lock/steering codes.
Old 06-23-2010, 11:39 AM
I used my friends ODBII scanner and did not get any codes.
Old 06-23-2010, 11:48 AM
A990 racer
A regular obd11 scanner will not access abs codes, you need a high line scanner such as Snap- On, MT or MTG 2500.
Old 06-23-2010, 10:17 PM
Okay, Thanks!
Old 05-11-2011, 08:45 AM
Dealer replaced EBC (Electronic Brake Control) Module.
Problem Fixed.
Thread is now dead.
Tags
abs , control , stability , steering , traction
