| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Lambo doors
If You Know: How Do I Go About Getting The Lambo Door Kit Who Sells Them?
dude did u try la google search i found these in like 10 sec
www.carhookups.com www.hondaacuraautoparts.com |
Thanks I Found What I Was Looking For About 1600$ Im Still Going To Get It But Not For A While....
with most cars, if you dont properly brace the frame, those kits will mess up a lot of things. maybe its different with hondas though.
www.decah.net
609-716-7385 They were the first to come out with a bolt on "lambo door kit." It's called the Decah VDC. Call and talk to Kevin. It's relativly easy to install, and complete bolt-on. Check it out. |
i hope honda doors are light, cause decah kits have been installed on the new tiburon doors(which are very heavy actually) and have totally fucked them up. the only proper way of doing this on a car with heavy doors is very expensive, and involves bracing a lot of the frame. if not done right, it can bend the roof, hood, frame, pillars, and door hinges.
Re: Lambo doors
its the stress it causes on the stock hinges, which in turn puts additional stress on everything they connect to.
here is a little search page i put together. "visionz" owns a body shop and knows what hes talking about. http://www.newtiburon.com/yabbse/ind...action=search2 |
Re: Lambo doors
Extremedimensions.com
Importfan.com They Have Them But Its Like $1600 For A Couple Of Hinges |
Re: Lambo doors
Umm, I hate to be the bearer of bad news, but the stock hinges ARE NOT part of the equation with this. They are removed, and replace with the componets to make the door open vertical (these can differ depending on which brand you buy). Therefor, it is not way can put stress on the stock hinge. Furthermore, as I said above, it connects to the frame under the fender, and to the door itself. Not the roof, not the pillar. None of that. I can post a pic if you don't believ me and require require. I also, know what I am saying. I am sponosered by DeCah, so of course I have would have the DeCah VDC. There are MANY types of "lambo door kits" out there, so maybe it;s a different type...maybe it's a problem on the tiberon.. Many are very different. What type is he using? I can assume you though. IN NO WAY will the DeCah VDC put pressure on the roof, pillar, or stock hinge. The Stock hinge is removed, and nothing is attached to the pillar or roof, sotck or otherwise. Also, there is no cutting, welding, etc. It's a bolt-on affair, and is completely reversable should you decide you want to go stock again. Last edited by eckoman_pdx; 01-21-2004 at 10:33 PM. |
sorry dood, im a moron. i didnt mean to type stock hinges, i meant the stock hinge mounting point. the tiburon door is heavy as shit, and the way it exert pressure on that mounting point with a lambo conversion is different. normally, the door would just make the top of the hinge want to rip off the mounting point. with the lambo conversion, it makes it want to rip out, but at a totally different angle. this causes stress on areas of the mounting point that werent designed for stress. and because that mounting point is connected to the pillar, and therefore connected to the roof, it just totally fucks everything up. but tiburon doors are 100+ lbs., so i doubt you'd have that problem with a civic door. other kits have been installed on the tiburon, with the same results. if any of you guys saw the lambo door APC 03 tiburon at SEMA, you would know what i am saying. they were uneven and scratching the body at certain points.
Re: Lambo doors
DoubleTap |
Re: Lambo doors
Re: Re: Lambo doors
