Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-08-2004, 10:05 PM
Ragai Ragai is offline
Can not remove key from ignition
Hello All,
I got Eighty eight LSS 1996. In cold weather I have to press very hard the shift stick button to be able to shift from "P". When I turn off the engine I can not rotate the key back to the "OFF" position and have to leave the key in the ignition. Searching the forum did not yield any results. Any ideas. Thanks
Old 01-10-2004, 11:50 AM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: Can not remove key from ignition
You might want check out your lock cylinder or ignition switch as they may need replacing.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 01-12-2004, 08:04 PM
Thanks for the reply it gave me a hint. I used some WD40 around the shift stick button and around the stick. Also, from the little hole closer to the floor. And, around the key cylinder. I also used a hair dryer to heat up both in between the sprays. Now, both work just fine. I noticed that the key cyliner is a bit loose. So, once the cold wave is gone, I probably should replace the key cylinder before it quits for good.
Thanks,
Can Not Remove Key - Key Release Solenoid MontanaDude Alero 2 09-30-2009 06:50 PM
Can not remove key from ignition bruceford F Series 0 06-30-2008 07:17 PM
Can not remove Key from 96 Bravada Daniel Blair Bravada 8 04-23-2007 11:08 PM
cannot remove key from ignition !! bobbyfrazer Regal 2 03-21-2006 11:27 PM
