Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-25-2005, 11:18 AM
Daniel Blair Daniel Blair is offline
Can not remove Key from 96 Bravada
What a great site this is!!!
Here is my problem. The ignition key in my 96 Bravada won't turn all the way back to the off position so the key can be removed. I found that there is a small solenoid in the column that prevents this unless the vehicle is in park. I have replaced the solenoid but that wasn't the problem. There must be a switch somewhere that activates this solenoid that I can't find. Does anybody have any idea where I should look next? Is there a switch in the floor shifter or in the transmission that activates this solenoid or am I barking up the wrong tree entirely.
Thanks for all of your help.
Dan
Old 11-25-2005, 11:41 AM
jharris26 jharris26 is offline
Re: Can not remove Key from 96 Bravada
i had this problem and it was just the wheel needed to be cranked in both directions very hard to get it to release the key. a friend had the same problem with an alero and we had to rock the car back and forth and turn the wheel to get it unstuck. hope that helps
Old 11-28-2005, 10:15 AM
minocqa minocqa is offline
Dan
hi
i had the same problem
and it was the battery that was bad.
hope this helps
Don
Old 11-28-2005, 10:46 AM
biv343 biv343 is offline
There's a switch in the floor shifter as well. I had the same issue with my 99, but my issue was a bad battery, same as the above poster mentioned. Voltage was high enough to turn on the dome lights, but not high enough to let the key release.
Old 11-28-2005, 05:06 PM
My Bravada's battery is fine, it runs well except for the key problem.
I have found that there is a small access hole on the underside of the steering colum that you can use to manually active the seleniod to get the key to release. I will look for the switch in the floor shifter. Thanks all for you assistance.
Old 01-17-2006, 02:14 PM
455_SS 455_SS is offline
i had the same problem with my wifes after dealership replaced ignition switch still problem..... i took apart the column housing it is a little silver cylinder button i taped it down (trusty ol' electrical tape) never had the problem again.
might be primative to some of you but do what it takes to save money and keep it going...
Old 01-17-2006, 05:56 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Thanks for the info 455SS
Old 04-23-2007, 01:26 PM
vy20 vy20 is offline
Same thing happened to my 97 bravada
The key cannot be removed from the igntion switch
So I actually opened up the panels under the dash area and took a look. There's this little silver cylinder on the passenger side of the steering colm, basically just press it down and remove the key...
Old 04-23-2007, 11:08 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
vy20, welcome to af. this thread is almost 2 and a half years old. please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
