Old 01-08-2004, 09:55 PM
adam38654 adam38654 is offline
mpfi swap trouble
hey, did you guys run both of the yellow with black stripe wires from the 2 old dx injectors to the ressistor box or just one? Also do you have to use the si ecu for this swap, also what order to the injectors fire in,
Old 01-08-2004, 11:07 PM
blade34609's Avatar
blade34609 blade34609 is offline
Re: mpfi swap trouble
I have heard you dont have to run both black stripe wires to the box but i ran both anyways.
yes, you will need the PM6 SI ecu for the swap to work correctly.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 01-09-2004, 09:51 AM
Re: Re: mpfi swap trouble
which swap tech did you use? would a 92-95 mpfi manifold work?
Old 01-09-2004, 10:23 AM
travagliante's Avatar
travagliante travagliante is offline
Yes every d-series manifold work work on your engine. 88-91 are very easy to put on followed by 92095 which arent much harder. Because you dont need the injector resistor box, but you have to wire obd1 if using obd1 injectors.
Old 01-09-2004, 10:33 AM
91civicDXdude's Avatar
just to clear up a common misconception, you can use obd1 injectors with an obd0 ECU as long as you wire in the resistor box
Old 01-09-2004, 11:03 AM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
i thought that you have to wire in the resistor box anyway. please explian. because i got the 92-95 intake manifold for the swap but havent done it yet.
also what do i do with the map sensor on top of the throdle body??[IMG][/IMG]
Old 01-09-2004, 11:15 AM
what im saying is that if you happen to have the OBD1 injectors with your OBD1 intake manifold, but you are using an OBD0 ECU, you can wire in the injector resistor box and use the OBD1 injectors with your OBD0 ECU..... one less thing to buy.
As far as the map sensor goes, you can either use it or the one of the firewall. there is no difference.
Old 01-09-2004, 12:34 PM
vesper's Avatar
for the map sensor. are the plugs the same or do i have to swap the out?
Old 01-09-2004, 02:13 PM
the plugs are identical. you can use either the firewall mounted map sensor or the throttle body sensor
Old 01-09-2004, 08:57 PM
do you still switch the 2 wires going to the TPS on the 92-95 intake? My injectors are fireing the same amount at idle and wot, i dont know whats wrong. Ecu runs code 20, i think thats circuit overload or power overload. Any one fallow a mpfi swap tech sucsessfull?
Old 01-09-2004, 10:42 PM
how do you use the map sensor on the firwall with the 92-95 intake manifold, mine is missing the map sensor on top of the TB
Old 01-10-2004, 01:51 PM
vesper's Avatar
i would just go buy a new one and then take the plug off the fire wall and plug it in. or if you can take the one off the fire wall and try to find a way to put it on the intake manifold dunno let me know how it works out.
Old 01-10-2004, 07:18 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
For those of you mixing and matching OBD-1 and OBD-0 allow me to clear up something which doesn't seem to be explained too well.
With OBD-0 injectors they are low impedance and require the use of an injector resistor box. The box turns down the power going to those injectors, if you have too much power going to them they will get fried. If you use OBD-1 injectors you DO NOT use an injector resistor box. OBD-1 injectors are high impedance and require more power to use them. You would simply solder the 4 same colored wires that would go to that box together, thus eliminating it.
For the intake manifolds it doesn't matter, they are just hunks of metal.
As for the TPS I believe you would still switch them because all the MPFI have the TPS turn the same way, the DPFI had them turn the other way so that is why you need to switch them around.
To use the MAP sensor on the OBD-1 manifold just extend the MAP sensor wires so they will reach to the engine and plug the vacuum hose onto the throttle body.
Old 01-10-2004, 08:31 PM
OBD1 injectors with an OBD0 ECU & *RESISTOR BOX* sure runs good enough to propel a SOHC VTEC to a 9.7 1/8 mile
Old 01-10-2004, 09:49 PM
vesper's Avatar
with obd1 injectors DO you or DO YOU NOT use a resistor box. there seems to be different opinions on this.
Mini Me Swap / Mpfi Swap Questions he_who_corrupts How-To's and Walk-Through's 1 11-28-2006 11:12 PM
semi complete MPFI swap for sale.... marked001 '71-'87 Civic | CRX 3 02-06-2006 03:36 AM
for those doing mpfi swap on crx or d16z6, d15 vtec swap Scott82 Classifieds 3 04-21-2005 06:37 PM
FS: Complete MPFI Swap mdnnccivicrcr '88 - '91 Civic | CRX | Wagon | Shuttlee 16 08-20-2002 11:24 PM
DPFI - MPFI swap crxlvr '88 - '91 Civic | CRX | Wagon | Shuttlee 22 07-29-2002 12:44 AM
