Old 01-07-2004, 02:59 AM
chuck'sZ chuck'sZ is offline
Question bang 4 the buck
i have approx. $1500 bucks to spend on my 94 Z28. i was wondering if anyone had any ideas about what to do to as far as building HP. I want to go faster and faster and faster
Old 01-07-2004, 08:08 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: bang 4 the buck
headers, free-flowing cat, cat-back exhaust, k&n air filter, intake manifold, heads, 3.73 gears, computer chip. those items should be a good start for ya.
Old 01-07-2004, 09:40 AM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: bang 4 the buck
Intake, Headers, Cat-Back, LT4 Knock Module, Gears, Programming... that should just about use it all up...
My Project Write-Up
Old 01-07-2004, 10:01 AM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Re: bang 4 the buck
Sent it to this account ###### I can use some stuff for my ute
Yeah yeah I know it looks like grandpa's but wait til I put the LT1 in it
Old 01-07-2004, 07:10 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: bang 4 the buck
No crap..... that would almost be enough to buy me a set of GN1 heads. Oh well guess Ill start saving.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-07-2004, 08:29 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: bang 4 the buck
obviously the headers and exhaust are a good idea, programming all that. also work on the other side of the air pump that is your engine. intake. port and polish the heads, a bigger throttle body, big valves in the heads. thermal coatings are good, but on a budget the effects are negligable. but if you want to, thermal coat the piston crown, valve faces and combustion chamber as well as the exhaust port. also antifriction coatings on the piston skirts and other bearings in the engine will free up horsepower. think of your engine as an air pump, anything you do to make it pump air more easily will make more power, also, anything you do to reduce friction in the engine will free up power from the rotating assembly. with that in mind, a crank scraper would be a good idea, make one of sheet metal. tap holes in the block on the main webbing, and screw it on. it should follow the profile of the crank and connecting rods with about a 1/8 inch gap. and fit inside the oil pan. dosnt do much at lower rpm's, but at higher rpms, can free up as much as 20hp.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Is the '06 Monte Carlo the best bang for buck? ghostx Car Comparisons 10 08-05-2005 07:16 PM
The most bang for the buck? veilsidercng '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 09-07-2004 10:19 AM
With Mods on a stock 89 Civic Si engine, is the resulting bang worth the bucks? Beast Engineering/ Technical 1 03-17-2002 06:39 AM
Bang for the Buck kheetar Engine 47 12-16-2001 05:53 PM
