Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-07-2004, 12:32 AM
Dalis Dalis is offline
2000 GMC Jimmy stalling
Hey guys looking for some input. Had a problem with my Jimmy
starting 1 month ago. Had to be jump started a number of times. So
I got a new battery put in under warranty and now the warranty is
expired. But between that time I've done a 50,000 km service. Oil
change, trans service, changed fuel filter and shampooed the
engine. What's happening now is that the engine stalls hot or cold
and intermittantly. Accelerating, coasting or at idle. When it
stalls it just dies and then restarts. It doesn't run rough at
all. At one time it would not start for almost 5 minutes. I've
scanned it and no trouble codes. Tried replacing the jobber fuel
filter with a GM filter. No luck. Tried even blowing down the
engine compartment thinking water on the connectors and dist. cap.
I've talked to the Dealer and no luck, they said never had this come
across. They talked about ignition switch but I do get all the dash
lights to light up when the problem occurs. They also said the cam
or crank sensor but it would've of logged a code. Now my next test
would be leaving a fuel guage hooked up and waiting for it to
stall.
I was hoping to get more info on other GMC Jimmy owners if they had
a problem somewhat similiar and what their fixes were.
Old 01-10-2004, 12:13 AM
Well here's an update and maybe hope it helps others.
I finally did get it to stall with the fuel guage hooked up. Pressure dropped from 54 psi down to about 40 psi. I tried swapping fuel pump relay with the horn which were the same part number and no luck. So I had a test light hooked up to the test port going to the fuel pump in the relay box beside the fuel pump relay. Off driving I go and got it to stall, light stayed on for about 5 seconds after it stall and pressure went down to 40 psi again. So computer, sensors and fuel relay good. I talked to the dealer and they say the injector poppets need exactly 49 psi to make them open, thus causing the fuel to shut off. Turns out to be the Fuel pump. So off to the dealer to get Goodwill on the fuel pump ($700 cdn) Hope this fixes it.
Old 01-10-2004, 12:24 AM
thepolishmafia1337 thepolishmafia1337 is offline
Re: 2000 GMC Jimmy stalling
i m sure that you did but just in case did you check for votalge drop during or after the stall. if the voltage to the fuel pump are inconsistand or if there is a bad ground it could cause that problem. just a thought
Old 01-11-2004, 12:03 AM
So last night it finally packed it in. The fuel pump didn't want to
go at all. It was on its' final legacy. Didn't start and no
humming noise. I bitched at the GM dealer and got a new fuel pump
under Goodwill. Had to have the truck towed and just got it back
tonight. And so far so good, no problems. Will keep u guys updated
if anything else does happen. But I think we'll end it here.
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 06:37 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
1997 GMC jimmy stalls-no start wig2160 Problem Diagnosis 1 11-17-2007 08:47 AM
2001 GMC Jimmy Stalls harlancountian Jimmy 10 07-19-2005 07:49 AM
1995 gmc jimmy stalls after warmup,has good fuel pressure automan431 Jimmy 3 03-21-2005 04:53 PM
Closed Thread
