Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-08-2005, 11:49 AM
automan431 automan431 is offline
1995 gmc jimmy stalls after warmup,has good fuel pressure
after vehicle has warmed up it stalls like module might be hot
however this was replaced and as well as fuelpump and misc.ignition parts
once temp goes down it starts and runs
it also does not have any engine codes
the fuel pressure stays between 60 and 65psi
all vaccum lines appear in tac
and cpi spider was treplaced within last 6 months
could the be a broken wire somewhere that opens or shorts after warmup and if so where could I look
Old 03-08-2005, 04:29 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Define good pressure.,...
Have you checked all your vac hoses?
Have you checked your CPI and nut kit?
Old 03-17-2005, 08:14 PM
gingersnaps gingersnaps is offline
Send a message via MSN to gingersnaps Send a message via Yahoo to gingersnaps
Re: 1995 gmc jimmy stalls after warmup,has good fuel pressure
yeah I have been having stalling problems with my truck after it warms up a bit too....the shop told me that the truck is getting all gas and no air...that might be your problem..I don't know
Old 03-21-2005, 04:53 PM
fuel pressure stays at 60 psi
ign module was replaced as well as tps
symptoms still there
no codes from obd2
seems like a wire might be broken and separates after warmup
any other suggestion would be helpful
thanks
