Old 01-06-2004, 08:39 PM
trav87 trav87 is offline
ignition problem
anyone have any ideas for my 87 chevy pick up? it's a 305 with a noticeable engine skip. changed plugs, wires, cap, rotor,and coil. good compression in all cylinders and good vacuum. think it's distributor related? I'm out of ideas. thanks
Old 01-06-2004, 10:11 PM
homefree's Avatar
homefree homefree is offline
Re: ignition problem
I had a 1989 305 that had broken valve springs and it ran kinda funny, do a comp check. The springs have a inner spring that was broken on mine. Good luck.
Old 01-07-2004, 05:40 PM
Re: Re: ignition problem
compression was good across all cylinders. changed distributor today and problem was still there. still puzzled......
Old 01-07-2004, 07:08 PM
RacinRex RacinRex is offline
Send a message via AIM to RacinRex Send a message via Yahoo to RacinRex
Hey Trav, something you might want to check is if I am correct it should be throttle body injected. If it is, make sure you have a nice wide spray out of the injector or try running some injector cleaner through it. How many miles are on the engine?
Old 01-20-2004, 04:41 PM
72 rs's Avatar
72 rs 72 rs is offline
i say itsthe computer, that was my prob.
Old 01-21-2004, 02:37 PM
RABarrett RABarrett is offline
You might try checking the compression while the engine is running. Check all of the cylinders, one at a time. The running compression should be the same on all cylinders. These engines were prone to camshaft related issues and a running compression check will indicate an issue of cylinder filling. Ray
Old 09-17-2005, 12:44 PM
ChevyBobby's Avatar
ChevyBobby ChevyBobby is offline
Ray, How much diferance should there be between engine Running compression test and cranking comprssion test with all spark plugs out?
Old 09-17-2005, 05:49 PM
ChevyBobby's Avatar
Is it possible for the computer to not fire 1 or 2 cylinders?
It seeming cylinder #1 an #3 are not firing. I did a cpmretion test.
With all plugs out and cranging the engine. All cylinders are 175 psi.
With the engine running all clinders are 75.psi. Anyone know if this is normal?
Spark plugs in cylinder #1 and #3 are a black. All the others are normal graying white like they are firing.
Old 09-17-2005, 09:42 PM
broughy84's Avatar
broughy84 broughy84 is offline
personally the first thing i would check is the throttle body gasket. Are the plugs fouled?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Ignition problem? Jeffstevehow Explorer | Explorer Sport Trac 1 06-22-2010 12:15 PM
93 del Sol si wont start, something isnt getting power TunerFreak24 Del Sol 12 02-08-2010 01:17 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 02:53 AM
ignition problem, transmission problem, you name it problem 1hotmama Sable 1 04-20-2004 12:17 PM
535i -86 Ignition problem jkr 5 Series 0 07-12-2002 08:17 AM
