| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
Alright, I am getting a little frustrated here. I had bottoming issues in the past few weeks and decided to upgrade to some better shocks. I got the beautiful koni reds and even raised my car slightly to try and prevent the bottoming out issues. I can fit my hand between the fenders and tires. I was told that the skunk2's have a a stiff spring rate and the ride may be a bit bouncy (but that's what I live for!). I have been in lowered tegs and civics and my car doesn't drive even close to one. No "race" bounce at all.1.How long do the springs generally last? I am thinking that my springs have been too compressed from exsessive lowering and blown shocks(previous owner). 2.Is there anyway to fix them or do I just to buy a new pair? 3.Since it is only the front that is having issues can I get away with just buying new springs for the front and upgrading the rears later? I know it takes time for suspension to settle in but shouldn't the ride be less prone to bottoming out after the spring has been uncompressed for some time? 4.Lastly, can I just keep the threaded body and buy replacement springs, or should I not bother with skunk2? Please HElp!!!
Re: Koni reds and skunk2's bottoming out!!!!!
Springs should last a long time unless they are defective. If you choose to go with new springs Skunk2's would be one of my LAST choices.
Are the factory bump stops in place? If so are they cust in half? You may be riding on them which is a terrible ride. |
Re: Re: Koni reds and skunk2's bottoming out!!!!!
You should get the poly urethane strut rod bump stops from prothane. They will last and perform a hell of a lot longer than the factroy units.
Turbo 351w E85 |
well that sucks cause I already ordered them and I had to pay before I even could order them.....DAMN
Are you sure you have the correct springs? Do you have the fronts on the rears and vice versa? You cannot really damage springs (take a very long time I mean there are cars with 300,000+ miles with stock springs).
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
Well that is a very good point seeing as how the bumpstops weren't even on the car after he dropped it. He put the wrong size tires on the car 215's, didn't change the shocks when he dropped the car, and had every single bolt over torqued. How can I tell....The only problem is I normally do two wheels at a time. I guess next time I will pull them all off and put the whole car up on jacks. How can I make sure the fronts are on the fronts and vice versa. Do the numbers mean anything on the springs themselves? Thanx for all your help guys...I just want to fix all this and not have to worry about supsension anymore. Would be nice to move on the engine, you know
Re: Re: Re: Koni reds and skunk2's bottoming out!!!!!
Call Skunk2 to make sure. When I had my coilovers installed by some no-name shop they put the front springs on the passenger side and the rear springs on the driver's side. I couldn't figure out why I couldn't get my car at a perfect height all around
Ok, sweet. I will take a look when I get my bump stops. I have a sneaking suspiscion that he put the stiffer springs in the rear. Kinda bummed though, cause I thought koni would supply the bumpstops...Guess that is only for the yellows. Do you know if the reds click at all when you adjust them or do I just have to pay attention to the amount of rotation when turning them? Do you know if the shock stays compressed while in adjusting. Heard I have to turn counter clockwise untill they lock in the adjusting "mode"(for lack of a better word).
Thnx for you help man! Wish me luck. Is that your car under your name? It looks sweet. |
And the car under my name isn't my daughter's Civic she's only 2 1/2 years old
haha...she's old enough to drive!!! I just put the bumpstops in and now NO more bottoming out, plus I blew one of my tires yesterday and just decided to replace both tires with 205's instead of the huge 215's that were installed. NO MORE RUBBING!!!!! I'm going to wait a another day or so but I want to go lower. Going to install the rears today. Think the springs are on the right side and everything though, just checked last night.
Do people use the upper half of the bumpstop or the lower half. I put the lower half in but I seem to recall people using the upper half! |
I usually use the top half, I don't think it really matters just as long as something is there.
Dont forget to get the car aligned. |
Just like jackasssi said he does, most people/places/manufacturers say to cut the bumpstops in half and use the upper half. I'd imagine that using the bottom half won't hurt any (though I'm not sure on that). At least it is better than having none or not cutting them at all. driving around with no bumpstops in a bad idea...much like driving around riding ON the bumpstops (which results from not cutting them in-half) is a bad idea.
![]() ![]() It's just that easy folks... mind the forum guidelines and we're cool. Empty Pockets Racing Member #6 EPR Member 4 Life |
