Old 01-06-2004, 02:45 PM
blade34609's Avatar
blade34609 blade34609 is offline
Si header on my STD hatch
Hi,
Since I am planning on replacing my head gasket in the hatch and I have to remove the header anyways to get to the head I decided to take the very restrictive STD header (with a CAT on it) and replace it with my SI one that I got from the SI engine I had.
Will it bolt right in place of the STD header and connect to the exhaust?
I was planning on buying an aftermarket header but since im low on $ and I removing the header anyways i want to know if its possible to do this. I should get a decent increase in HP right? I have the MPFI swap completed also.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 01-06-2004, 03:02 PM
91civicDXdude's Avatar
it will bolt right up and you will have no cat.
Old 01-06-2004, 03:46 PM
blade34609's Avatar
Will it be a lot louder with no cat?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 01-06-2004, 05:48 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Si header on my STD hatch
Yes, lots louder with no cat. Depending on if you have factory muffler or straight through design style.
Check out my car here My 91 Hatch
Old 01-06-2004, 06:49 PM
blade34609's Avatar
Ok, how much HP do you think the STD cat is restricting the car with an MPFI swap?
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 01-06-2004, 08:58 PM
alexdog69's Avatar
alexdog69 alexdog69 is offline
a lot
D16Z6 into STD hatch? Riddick '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-18-2004 09:30 PM
B18a1 Wiring in STD. Hatch KoRnSaQ '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-02-2004 10:58 AM
STD Hatch Specs blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 11-18-2003 06:06 PM
putting D15b7 into my STD hatch BLU CIVIC '88 - '91 Civic | CRX | Wagon | Shuttlee 10 09-23-2003 02:29 PM
I hope my neighbor sells his STD Hatch... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-21-2002 05:26 AM
