Old 09-22-2003, 06:34 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
putting D15b7 into my STD hatch
i'm sure this is redundant
i recently brought a d15b7 out of a 95 dx to replace the d15b1 that has a blown head gasket......the guy gave me the engine, tranny, axles, shift linkage, motor mounts, intake manifold, header and downpipe, and entire wiring harness for $100. the thing is that it has a hydro tranny and is obd1. i figure that i have everything i need except the ecu.
here's my question....can i put this set-up in my car using the hydro tranny and convert my car over to obd1?? i know that it is possibe...but i don't know everything that is envolved and i don't know if i'm able to use that tranny also
thanx for the help
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-22-2003, 07:28 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
u can always run the hydro lines cause i dont think hasports came out with the cable to hydro for the d series. converting to obd1 isnt that hard, people sell conversion harnesses. like u say its possible but if you want to spend the money and time doing it.
also i heard that a 5th gen head on a hf block is the shit, good for like 15s or soemthing liek that cause suppose to yield mad compression, idk something i heard
Team Lonely Drivers
Old 09-22-2003, 07:57 PM
BLU CIVIC's Avatar
調整器
this is a dx....haven't heard that about the HF head....
ok...ami already told me about the tranny....but itz always good to have a second opnion now i gotta find a conversion harness
The name's Adrian
2011 CR-Z - Stock
Old 09-23-2003, 05:00 AM
GTA's Avatar
GTA GTA is offline
Whee..
www.jkobdconversionharness.com
this is the guy from honda-tech everyone always recommeneds. i will be getting one from him and ami got hers from him also.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-23-2003, 08:29 AM
jackacc's Avatar
jackacc jackacc is offline
I am a satisfied customer as well... definately get one of these harnesses. Very cool guy and he is a wealth of knowledge to help with the wiring headaches.
Old 09-23-2003, 08:34 AM
BLU CIVIC's Avatar
調整器
it says my car needs to be mpfi.....so i guess i just need the resistor box and get a dx/lx ecu........can't i use the ex ecu??
The name's Adrian
2011 CR-Z - Stock
Old 09-23-2003, 09:54 AM
BLU CIVIC's Avatar
調整器
NEVERMIND.....vtec engine
The name's Adrian
2011 CR-Z - Stock
Old 09-23-2003, 01:43 PM
91civicDXdude's Avatar
the d15b7 is basically an obd0 engine, even though technically its OBD1. Use a PM6 ECU and wire in an injector resistor box. You can even use the OBD1 injectors as long as you have the resistor.
Old 09-23-2003, 01:56 PM
BLU CIVIC's Avatar
調整器
that sounds cool.....but i have to find a wire harness b/c i don't think i can use the b7 harness....
but i have a guy that might trade me a PM6 ecu, resistor box, si intake manifold and injectors for the b7 wiring harness.....hopefully he agrees
The name's Adrian
2011 CR-Z - Stock
Old 09-23-2003, 03:26 PM
use the B7 intake manifold, and also you'll have to get an OBD0 MPFI Distributor.
Old 09-23-2003, 03:29 PM
BLU CIVIC's Avatar
調整器
So I Can Use The Intake Manifold From The B7....cool.....now I Just Need A Wiring Harness From A 88-91 Civic Si
The name's Adrian
2011 CR-Z - Stock
b16a1 into 89 std hatch BIGTEX84 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 02-16-2009 10:28 PM
D16Z6 into STD hatch? Riddick '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-18-2004 10:30 PM
Si header on my STD hatch blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-06-2004 09:58 PM
STD Hatch Specs blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 11-18-2003 07:06 PM
I hope my neighbor sells his STD Hatch... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-21-2002 06:26 AM
