Old 11-17-2003, 04:29 PM
blade34609's Avatar
blade34609 blade34609 is offline
STD Hatch Specs
Hi,
As you know I just bought a 1988 Civic Hatch STD with the 4 speed tranny. It is my project car so im the meantime I drive my 90 4G4D.
ANyways, I researched this car and I read it only has 70 hp.
But I poped the hood on my Civic LX Sedan and the engine look almost identical. Is the head different from the DX 92hp engine?
My engien is a D15b1 and the DX has a D15B2 correct?
I am going to do the MPFI swap on the STD and someone told me it will add about 25-30hp because of the multi Port system.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 11-17-2003, 06:07 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: STD Hatch Specs
Every thing is the same on the STD and the DX except for the intake manifold the ecu and the tranny. I may have forgot a couple of things.
Check out my car here My 91 Hatch
Old 11-17-2003, 09:47 PM
blade34609's Avatar
Re: Re: STD Hatch Specs
LOl, not like im gonna do it. But so if every thing is the same on the DX and STD hatch except ECU and manifold. Couldnt I take the DX manifold and ecu and put in the teh STD. and Take the STD manifold and ecu and put it in my sedan? Using the same wiring harnesses?
So I would end up with a hatch with 92hp and a sedan with 70hp lol.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 11-17-2003, 11:50 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: STD Hatch Specs
I believe that the throttle bodies are different also.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 11-18-2003, 12:05 AM
Re: STD Hatch Specs
Yeah something like that.
Old 11-18-2003, 05:21 PM
blade34609's Avatar
So can I just take a DX ECu and manifold and just replace all the STD ones? It would just be plug in right?
So I would go from 70hp to the 92hp DX engine?
I may be able to get a DX ecu and manifold for cheap.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 11-18-2003, 07:06 PM
Yeah but if your gunna go through all of the trouble of switching out for Dx shit you might as well go the x-tra mile and do the MPFI and if your gunna do the MPFI you might as well do a whole motor swap and wire the 2 wires for Vtec also.
D16Z6 into STD hatch? Riddick '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-18-2004 10:30 PM
B18a1 Wiring in STD. Hatch KoRnSaQ '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-02-2004 11:58 AM
Si header on my STD hatch blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-06-2004 09:58 PM
putting D15b7 into my STD hatch BLU CIVIC '88 - '91 Civic | CRX | Wagon | Shuttlee 10 09-23-2003 03:29 PM
I hope my neighbor sells his STD Hatch... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-21-2002 06:26 AM
