Old 01-06-2004, 12:20 PM
RISKINAZ RISKINAZ is offline
Installed A New Deck..
I Just Installed A New Sony Xplode In My 95 Accord And The Wiring Isnt Correct. When I Take The Key Out And Put Back In The Ignition I Lose All The Memory On My Clock And Radio Settings (goes Back To Factory Presets)... Which Color Wires Do I Have Incorrect?? Any Help Will Be Appreciated.. Thanks
Old 01-06-2004, 02:30 PM
starkfu's Avatar
starkfu starkfu is offline
Send a message via ICQ to starkfu Send a message via AIM to starkfu Send a message via Yahoo to starkfu
Re: Installed A New Deck..
sounds like your 12v constant and switched are reversed, or your ground isn't really a ground. From the head unit they are yellow, red, and black respectively, if you used a wiring harness they should be labeled.
***If knowledge is power, then a god am I***
<<former PH abyss member>>
1991 Acura Integra GS mods:
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Power slot rotors and EBC pads
Gutted
Blown motor
Looking for B18C5
1994 Honda Accord EX
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Just bought this car, more to come.
Old 01-06-2004, 02:41 PM
Mmmmmm
From Wiring Harness Yellow(constant 12v) Attached To Blue W/ White Stipe..
From Wiring Harness Red Attached To Red And Yellow
When I Put Red To Red And Yellow To Yellow No Power...
What Is Usually Standard Color For Remote???
Old 01-08-2004, 12:55 AM
tibby01 tibby01 is offline
yellow is almost always attached to yellow and red is the same. its been the same in every car ive seen. maybe you just had the battery unhooked or something when you tried to turn it on with the proper wires together.
Old 01-08-2004, 01:29 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
blue is usually the standard color for your remote wires. Are you using a wiring harness or did you cut off your factory wiring harness and hard wire your cd player in there?
Empty Pockets Racing Member #1
Old 01-08-2004, 11:57 AM
starkfu's Avatar
are you using a harness for the car's side of the wires or is this a direct wire to the harness on the radio. If you are direct wiring consult an online manual for your cars wire configuration.
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Gutted
Blown motor
Looking for B18C5
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Installing new speakers, new deck, subs and an amp, would like some help please atmalan SC/SL/SW 8 01-21-2005 06:12 PM
93 CAV install new deck RenegadeTrucker Cavalier 2 05-26-2004 10:09 PM
Front Panel Lights went out after installing new stereo deck dmandave Legacy / Liberty / Baja 5 12-06-2003 07:03 AM
Installing new 6x9s in the rear deck bmoney153 General Discussions 2 05-31-2003 02:31 AM
