Old 01-06-2004, 06:43 AM
6homer 6homer is offline
2003 wire color and location
Not having much luck with the wife's xmas present.
I need the color of the trigger wire for the door locks.
I posted a couple of days after xmas and got some responses
but wht/drk grn is not the trigger wire on a 2003. I'm told
the wiring for 03 changed from 02. If you but from IC Dynamics
don't expect much from customer service, i can't get through
during business hours and no e-mail response back as of yet.
The box works so I guessed the other wires correct but can't
get doors to lock or unlock. Anybody?
Thanks.
Old 01-08-2004, 12:55 AM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
2003 Dodge Caravan Security Information
Constant 12V+ Red or Pink/Black Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Dark Blue Ignition Switch Harness
Ignition 2 Dark Green/Red Ignition Switch Harness
Accessory Black/White Ignition Switch Harness
Tach Gray/Red Or Blue/Tan PCM Coil 2.4 Liter Engine
Neutral Safety Wire Black/White Power Control Module
Brake Switch White/Tan Brake Switch
Trunk Pin Tan/Black 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) Head Light Switch Harness left of Column
Head Lamp Green/Orange Light Switch
Hood Pin Brown Driver's Side under Hood
Factory Disarm White/Dark Green (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green (-) BCM at Fuse Panel 1500 Ohm Resistor
Door Unlock White/Dark Green (-) White Connector B58 Connector 250 Ohm Resistor
Driver's Lock Brown (+) Junction Block
Driver's Unlock Purple/Yellow (+) Junction Block
Horn Wire Black/Red Steering Column
Windows Up LF=Light Green, RF=Brown, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple, LR=Red, RR=Dark Green
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
Old 01-08-2004, 12:59 AM
2003 Dodge Caravan Cruise Information
Constant 12V+ Red or Pink/Black Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Dark Blue Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake Pink/Blue Brake Switch
Cold Side of Brake White/Tan Brake Switch
VSS Lead White/Orange Black 40 Pin Connector Driver's Front Quarter, Pin 66 at ECM
Pulses Per Mile 8000 PPM
Rostra Control Arm 250-3421
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
Old 01-08-2004, 01:00 AM
2003 Dodge Caravan Stereo Information
Constant 12V+ Pink
Switched 12V+ Red/White
Ground Ground/Back Strap
Illumination Black/Yellow
Dimmer n/a
Antenna Right Front
Front Speakers 5 1/4" Dash
Left Front (+) Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Blue/Red
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Blue/Orange
Right Rear (-) Blue/White
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
anyone with a 4.0L: need help with wiring plug connections and wire colors randy78 Cherokee 0 08-14-2009 04:12 PM
o2 signal wire color & pin location?? papiichuulo F Series 0 10-30-2008 03:42 PM
wire connections and locations for all 2002-2005 coolblink TrailBlazer | Trailblazer EXT 6 04-11-2006 02:53 PM
01 Odyssey: Speed Pulse wire color and location acvnate Odyssey 1 03-20-2005 04:58 PM
2003 Radio wiring color codes 03xtremeSC S-10 5 12-22-2004 07:07 AM
