here are the connections if i dont get to your yr, ill get it later today let me know if it helped.
2002 Accessory 12volts red (x2) + ignition harness Ignition pink + ignition harness Parking Lights+ brown driver kick panel Parking Lights- gray/black headlight switch Headlight white - headlight switch Speed Sense green/white blue plug, pin 32 @ PCM The PCM (Powertrain Control Module) is on the driver side of the motor LF Window up/dn blue - brown A driver door module in door RF Window up/dn lt. blue-tan A pass. door module in door LR Window up/dn blue-brown A LR window switch in door RR Window up/dn blue-brown A RR window switch in door Sun Roof open/close blue/red-blue A sun roof motor Audio Radio 12v orange + radio harness Radio Ground black/white - radio harness Radio Illumination brown/white (dimmer) + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - gray radio harness RF Speaker +/- lt. green - green radio harness LR Speaker +/- brown - yellow radio harness RR Speaker +/- blue - lt. blue radio harness Security 12volts red (x2) + ignition harness Starter yellow + ignition harness Ignition pink + ignition harness Power Lock module is need or see door lock gram below(last post) Power Unlock see Power Lock Lock Motor gray driver door module in door Unlock Motor tan driver door module in door Parking Lights+ brown driver kick panel Parking Lights- gray/black headlight switch Door Trigger gray/black + underdash light *See Note* *To avoid dome light delay, use the separate door trigger wires. The LF door is gray/black (-) at the driver door module in the door. The RF door is black/white (-) at the passenger door module in the door. The LR door is lt. blue/black (-), and the RR door is lt. green/black (-). The rear door trigger wires are at the fuse box under the left rear seat. Use all four wires and diode isolate each wire. Dome Supervision comes on with disarm Factory Alarm Disarm lt. green - driver door module in door Horn Trigger black or black/yellow - steering column Remote Start 12volts red (x2) + ignition harness Starter yellow + ignition harness Ignition pink + ignition harness Second Ignition white + ignition harness Accessory orange + ignition harness Second Accessory brown + ignition harness Keysense lt. green - ignition harness Power Lock module is need or see door lock diagram below(last post) Power Unlock see power lock Lock Motor gray driver door module in door Unlock Motor tan driver door module in door Parking Lights+ brown driver kick panel Parking Lights- gray/black headlight switch Reverse Light lt. green + fuse box under rear seat Door Trigger gray/black + underdash light *See Note* To avoid dome light delay, use the separate door trigger wires. The LF door isgray/black (-) at the driver door module in the door. The RF door is black/white (-) at the passenger door module in the door. The LR door is lt.blue/black (-), and the RR door is lt. green/black (-). The rear door trigger wires are at the fuse box under the left rear seat. Use all four wires and diode isolate each. Dome Supervision comes on with disarm Trunk/Hatch Pin common with door trigger wire Hood Pin pink/black - pin switch or BCM Trunk/Hatch Release To avoid dome light delay, use the separate trigger wires at the liftgate module in the liftgate. The liftgate is pink/black (-) and the glass hatch is purple (-).Use both wires and diode isolate each. Factory Alarm Disarm lt. green - driver door module in door Tachometer white blue plug, pin 49 @ PCM The PCM (Powertrain Control Module) is on the driver side of the motor. Brake Wire white + brake pedal switch Horn Trigger black or black/yellow - steering column Last edited by coolblink; 01-20-2005 at 09:30 AM. |
Remote Start/ Security /Keyless 12volts red (x2) + ignition harness Starter yellow + ignition harness Second Starter N/A Ignition pink + ignition harness Second Ignition white + ignition harness Third Ignition N/A Accessory orange + ignition harness Second Accessory brown + ignition harness Keysense lt. green - ignition harness Power Lock module is need or see door lock diagram below(last post) Power Unlock see power lock Lock Motor gray driver door module in door Unlock Motor tan driver door module in door Parking Lights+ brown + driver kick panel Parking Lights- gray/black - headlight switch Reverse Light lt. green + fuse box under rear seat Door Trigger gray/black + underdash light or driver A pillar To avoid dome light delay, use the separate door trigger wires. The LF door is gray/black (-) at the driver door module in the door. The RF door is black/white (-) at the passenger door module in the door. The LR door is lt. blue/black (-), and the RR door is lt.green/black (-). The rear door trigger wires are at the fuse box under the left rear seat. Use all four wires and diode isolate each Dome Supervision comes on with disarm Trunk/Hatch Pin common with door trigger wire To avoid dome light delay, use the separate trigger wires at the liftgate module in the liftgate. The liftgate is pink/black (-), and the glass hatch is purple (-). Use both wires and diode isolate each Hood Pin pink/black - pin switch or BCM Factory Alarm Disarm lt. green - driver door module in door Disarm No Unlock see factory alarm disarm Tachometer white ac blue plug, pin 49 @ PCM The PCM (Powertrain Control Module) is on the driver side of the motor. Brake Wire white + brake pedal switch Horn Trigger black or black/yellow - steering column Audio Radio 12v orange + radio harness Radio Ground black/white - radio harness Radio Ignition N/A Radio Illumination brown/white (dimmer) + radio harness Factory Amp Turn-on see pic (Last post) Power Antenna gray + radio harness LF Speaker +/- tan - gray radio harness RF Speaker +/- lt. green - green radio harness LR Speaker +/- brown - yellow radio harness RR Speaker +/- blue - lt. blue radio harness Accessory 12volts red (x2) + ignition harness Ignition pink + ignition harness Parking Lights+ brown + driver kick panel Parking Lights- gray/black - headlight switch Headlight white - headlight switch Speed Sense green/white blue plug, pin 32 @ PCM The PCM (Powertrain Control Module) is on the driver side of the motor LF Window up/dn blue - brown A driver door module in door RF Window up/dn lt. blue - tan A pass. door module in door LR Window up/dn blue - brown A LR window switch in door RR Window up/dn blue - brown A RR window switch in door Sun Roof opn/cls blue/red - blue A sun roof motor Last edited by coolblink; 01-20-2005 at 10:16 AM. |
Remote Start / Security / keyless 12volts red (40A), red/white (40A) + ignition harness Starter yellow + ignition harness Ignition pink + ignition harness Second Ignition white + ignition harness Accessory orange + ignition harness Second Accessory brown + ignition harness Keysense lt. green - ign harn or BCM, tan plug, pin E3 *Note* * The BCM is attached to the fuse box under the left rear seat.* Power Lock module is need or see door lock diagram below(last post) Power Unlock see power lock Lock Motor gray 5wi driver door module in door Unlock Motor tan 5wi driver door module in door Parking Lights+ brown + fuse box under left rear seat Parking Lights- gray/black - switch or BCM, tan plug, pin E5 Hazards white - steering column Turn Signal(L) dk. green + steering column Turn Signal(R) lt. green + steering column Reverse Light lt. green + fuse box under left rear seat Door Trigger gray/black + fuse box under left rear seat *Note* To avoid dome light delay, use the separate door trigger wires. The LF door is gray/black (-) at the driver door module in the door. The RF door is black/white (-) at the passenger door module in the door. The LR door is lt. blue/black (-), and the RR door is lt. green/black (-). The rear door trigger wires are at the fuse box under the left rear seat. Use all four wires and diode isolate each. Dome Supervision comes on with disarm Trunk/Hatch Pin common with door trigger wire *Note* * To avoid dome light delay, use the separate trigger wires at the liftgate module in the liftgate. The liftgate is pink/black (-), and the glass hatch is purple (-). Use both wires and diode isolate each. * Hood Pin pink/black (export only) - switch or BCM, tan plug, pin E6 Disarm No Unlock lt. green - driver door module in door Tachometer white ac PCM *Note* *4.2L: The PCM is attached to the driver side of the engine. Tach is in the blue plug, pin 49.* *5.3L: The PCM is near the lower front driver side of the engine. Tach is in the green plug, pin 10.* Brake Wire white + brake pedal switch Parking Brake lt. blue - switch or BCM, blk plug, pin A4 Horn Trigger black/yellow to black - column or BCM, tan plug, pin E12 Memory Seat 1 white + driver door module in door Memory Seat 2 purple + driver door module in door Accessory 12volts red (40A), red/white (40A) + ignition harness Ignition pink + ignition harness Parking Lights+ brown + fuse box under left rear seat Parking Lights- gray/black - switch or BCM, tan plug, pin E5 Headlight white - switch or BCM, tan plug, pin F9 Speed Sense dk. green/white PCM *Note* * 4.2L: The PCM is attached to the driver side of the engine. VSS is in the blue plug, pin 32. * * 5.3L: The PCM is near the lower front driver side of the engine. VSS is in the green plug, pin 50. * Wipers pink (L), dk. blue (H) +,- steering column LF Window up/dn dk. blue - brown A driver door module in door RF Window up/dn lt. blue - tan A frt pass door module in door LR Window up/dn dk. blue - brown A LR window switch in door RR Window up/dn dk. blue - brown A RR window switch in door Sun Roof open/close dk. blue/red - dk. blue A motor at rear of sunroof Memory Seat 1 white + driver door module in door Memory Seat 2 purple + driver door module in door Audio Radio 12v orange + radio harness Radio Ground black/white - radio harness Radio Ignition Class 2 Serial Data Radio Illumination Class 2 or brown/white + radio harness Factory Amp Turn-on Class 2 or pink + radio harness *Note* * The amplifier is in the passenger side rear quarter panel see pic on last post* LF Speaker +/- tan - gray +,- radio harness or amp RF Speaker +/- lt. green - dk. green +,- radio harness or amp LR Speaker +/- brown - yellow +,- radio harness or amp RR Speaker +/- dk. blue - lt. blue +,- radio harness or am Last edited by coolblink; 01-20-2005 at 11:03 AM. |
Remote Start / Security / keyless 12volts red (40A), red/white (40A) + ignition harness Starter yellow + ignition harness Ignition pink + ignition harness Second Ignition white + ignition harness Accessory orange + ignition harness Second Accessory brown + ignition harness Keysense lt. green - ign harn or BCM, tan plug, pin E3 * Power Lock module is need or see door lock diagram below (last post) Power Unlock see power lock Lock Motor gray 5wi driver door module in door Unlock Motor tan 5wi driver door module in door Parking Lights+ brown + fuse box under left rear seat Parking Lights- gray/black - switch or BCM, tan plug, pin E5 Hazards white - hazard switch Turn Signal(L) dk. green + turn signal switch Turn Signal(R) lt. green + turn signal switch Reverse Light lt. green + fuse box under left rear seat Door Trigger use dome supervision wire - see notes *** Dome Supervision gray/black + fuse box under left rear seat Trunk/Hatch Pin use dome supervision wire **** Hood Pin pink/black (export only) - switch or BCM, tan plug, pin E6 Disarm No Unlock lt. green - driver door module in door Tachometer white ac cluster or PCM/ECM, blue plug ***** Brake Wire white + brake pedal switch Parking Brake lt. blue - switch or fuse box under LR seat Horn Trigger black/yellow to black - switch or BCM, tan plug, pin E12 Memory Seat 1 white + driver door module in door Memory Seat 2 purple + driver door module in door Accessory 12volts red (40A), red/white (40A) + ignition harness Ignition pink + ignition harness Parking Lights+ brown + fuse box under left rear seat Parking Lights- gray/black - switch or BCM, tan plug, pin E5 Headlight white - switch or BCM, tan plug, pin F9 Speed Sense dk. green/white cluster or PCM/ECM, blue plug ** Wipers pink (L), dk. blue (H) +,- windshield wiper switch LF Window up/dn dk. blue - brown A driver door module in door RF Window up/dn lt. blue - tan A front passenger door module in door LR Window up/dn dk. blue - brown A LR window switch in door RR Window up/dn dk. blue - brown A RR window switch in door Memory Seat 1 white + driver door module in door Memory Seat 2 purple + driver door module in door Audio Radio 12v orange + radio harness Radio Ground black/white - radio harness Radio Ignition (Class 2 Serial Data) Factory Amp Turn-on pink + radio harness *Note* *The amplifier is in the passenger side rear quarter panel.* LF Speaker +/- tan - gray +,- radio harness or amplifier RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier LR Speaker +/- brown - yellow +,- radio harness or amplifier RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier *****NOTE***** *The BCM is attached to the fuse box under the left rear seat. **Speed Sense** 4.2L: The PCM is attached to the driver side of the engine. VSS is in pin 32. 5.3L: The ECM is near the lower front driver side of the engine. VSS is in pin 21. ***To avoid dome light delay, use the separate door trigger wires. The LF door is gray/black (-) at the driver door module in the door. The RF door is black/white (-) at the passenger door module in the door. The LR door is lt. blue/black (-), and the RR door is lt. green/black (-). The rear door trigger wires are at the fuse box under the left rear seat. Use all four wires and diode isolate each. ****To avoid dome light delay, use the separate trigger wires at the liftgate module in the liftgate. The liftgate is pink/black (-), and the glass hatch is purple (-). Use both wires and diode isolate each. ***** Tachometer 4.2L: The PCM is attached to the driver side of the engine. Tach is in pin 49. 5.3L: The ECM is near the lower front driver side of the engine. Tach is in pin 48. Can also go to any fuel injector and use the wire that is NOT pink. Last edited by coolblink; 01-20-2005 at 11:39 AM. |
Mods/Admin. I think this post should be made into a sticky so that it stays on the top of forum at all times since it has so much useful info that is requested alot by other members.
Re: wire connections and locations for all 2002-2005
bump
could you post some Picture or drawings
