Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 03-20-2005, 04:30 PM
acvnate acvnate is offline
01 Odyssey: Speed Pulse wire color and location
I am installing a Pioneer AVIC N2. The instructions want me to make a connection to the speed pulse wire / speed sensor wire. Can anyone help me locate it under the dash? Thank you for your help and time. Nate
Old 03-20-2005, 04:58 PM
lorunner lorunner is offline
Re: 01 Odyssey: Speed Pulse wire color and location
There is a wire that goes from the PCM to the speedo assuming thats what you need. Its blue/white wire. pin 9 in connector A of the PCM or pin 2 of connector B on the back of the gauge cluster. There are no connectors inbetween that can be accessed. Since your doing a radio it would probably be easier to remover the gauge cluster.
Connector B is a green 22 pin connector, pin 1 is blue, pin 2 is blue with white pin 3 is red/blue and pin 4 is red/white. pin 11 which is right under pin 1 is yellow. That should help you get your position on the connector when you look at it so you know you have the right wire.
Stop asking me about radio codes I cant get them anymore!!!
