Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 01-06-2004, 01:12 AM
tsc6044
Guest
Posts: n/a
Question 2001 Jetta Engine Problem
Please let me know if anyone else is having this problem. My dealer thinks I'm making things up...
I have a 2001 Jetta GLS automatic with 55,000 miles. Sometimes when I start my car, the ignition won't catch right, I apply the gas and the car will coast for maybe 20 feet, and if I try to further apply the gas, I get a loud grinding noise, like metal on metal. I have to stop the car and wait a few minutes before attempting to start it again. Most times, the second try won't catch either. Third time usually does it, but my point is, this shouldn't even be happening.
This always occurs, for some odd, unexplainable reason, when I drive from my house to the bank about 15 miles away by highway, so roughly speeds of 60-70 mph. I'll have the car turned off for less than five minutes, then when I attempt to start it, my problems begin. The dealer made a lame joke that I just shouldn't go to the bank anymore. But this has happened on other occassions, again, going short distances, stopping the car for a few minutes, then restarting. Sometimes it does it after going short distances at slower speeds, maybe 30-40 mph.
Weather doesn't seem to be a factor, nor does the amount of gas in the tank. I have had the fuel relay and pistons replaced, so I don't know if that has anything to do with it, since I've had this problem for some time now.
I love my car when it works properly, and hate the thought of having to turn it in and buying something else. Can anyone help me??
Old 01-06-2004, 10:15 AM
miro1118 miro1118 is offline
Re: 2001 Jetta Engine Problem
sounds like transmission to me. Flywheel/torque converter. If ignition does not catch you could me missing a tooth.
Old 02-18-2004, 10:58 AM
layinframe_95 layinframe_95 is offline
Send a message via MSN to layinframe_95
Does the car start ok? If it does, it sounds like maybe a tooth on your drive gear has sheered off. If it's not starting right, i'd have the stall converter checked.
2001 Jetta Acceleration Problem flyshigh007 '97 - '03 4 10-29-2011 08:11 PM
HELP- 2001 Jetta engine misfire cjamesz24 '97 - '03 1 07-30-2008 09:54 PM
2001 Jetta Engine Swap jetta2001 '97 - '03 1 01-28-2006 11:38 AM
2001 Jetta Blinker problem GMonroy '97 - '03 5 02-04-2005 04:33 PM
2001 Jetta TDI problem with check engine light nmudd '97 - '03 3 01-23-2005 09:48 PM
