Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 01-06-2004, 12:46 AM
ArtCan ArtCan is offline
Ignition problems
Hi there. I have a 1998 Dodge Stratus that was working fine up till today. I started the car a few times today due to the cold weather and on the last time, the car wouldn't start. Just click, click, click. What is weird is that the lights, oil light and electronic odometer never went out with the keys out. I towed it to a shop where they boosted the car. Car started except the starter does not disengage. Also, when you turn the key, the car starts at the accesory stage. I have replaced the battery and also have noticed a fuse under the hood that was blown( can't remember which one, but it was a 20). When I replace that fuse, the car starts automatically without a key. I was told by a friend that it could it be the ignition switch that may be stuck? Any ideas?
Old 03-27-2004, 06:32 PM
MrRoscoePC MrRoscoePC is offline
Ignition switch
The starter or wiring at the starter coil is shorted and needs replacing.
RG
Old 04-21-2004, 06:47 PM
rruddfan21 rruddfan21 is offline
starter solenoid may be bad
Old 05-04-2004, 02:10 AM
Al_Bundy's Avatar
Al_Bundy Al_Bundy is offline
Re: Ignition problems
Could be the ignition switch, lights should turn off when key is out and shouldn't start without key in.
Your friends sounds pretty good advice, check into it.
Ignition problem? Jeffstevehow Explorer | Explorer Sport Trac 1 06-22-2010 12:15 PM
93 del Sol si wont start, something isnt getting power TunerFreak24 Del Sol 12 02-08-2010 01:17 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 02:53 AM
ignition problem, transmission problem, you name it problem 1hotmama Sable 1 04-20-2004 12:17 PM
535i -86 Ignition problem jkr 5 Series 0 07-12-2002 08:17 AM
