Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-03-2004, 10:19 PM
broncokev broncokev is offline
Angry 4x4 88' push button switch does nothing no lights
I have 1988 broncoII. My push button switch has extremly low light and switch does nothing.Went to pick apart change switch and 4x4 control module.still nothing. Switch does nothing. Check power to control module
there is power there.No fuses are blown.the light is so dimm you can hardly see it.any help please
Old 01-05-2004, 10:42 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: 4x4 88' push button switch does nothing no lights
With the key on engine off, can you hear something clicking when you push the button
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-06-2004, 05:41 PM
Re: push button switch does nothing no lights
thanks for answering. No there is no clicking.Imgetting like 3 volts at the switch red/yellow wire on switch
Old 01-07-2004, 06:23 PM
Hypsi87's Avatar
Re: Re: push button switch does nothing no lights
let me do some research... in the meantime just try this for shits and giggles. Have a buddy sit in the drivers seat and just push the button repeatadly. While he does this get under it and tap on the little eletric motor on the back of the transfer case. and see what happens.
Andy.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 07-21-2005, 08:21 AM
INNES's Avatar
INNES INNES is offline
can anyone tell me how this conversation ends cause im having the same problem now thankyou in advance
it ended 1/7/04, its now 7/21/05
Old 03-09-2006, 01:14 PM
bronc bronc is offline
you should look for a bad wire connection on the passenger side kick panel.My 90 bronco had the same problem.there will be a plastic connectio with two wire feed into it.I have a fullsize but I bet it is still the same setup.I got a switch off a bronco2 for mine but found the wire problem fixed it.
Old 03-12-2006, 08:12 PM
locate the reset button on the pass side kick panel has two wires on each side
High Beam Push Button Switch on 91 Caprice Classic Candy_andy727 Caprice 5 10-18-2007 09:55 PM
4x4 Switch does nothing? nit78 Yukon 0 11-15-2005 11:51 PM
2002 O/D Switch does Nothing PeterKoegel Grand Cherokee | Grand Cherokee SRT8 1 07-09-2005 03:15 AM
Just got a 00 4runner and heating control selector switch does nothing RyanSR5 4Runner/GX470 0 01-02-2005 02:08 PM
Push button for wheel drive light? Mr_Meanor S-10 0 03-13-2003 11:43 PM
