Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-31-2005, 01:27 PM
Candy_andy727 Candy_andy727 is offline
High Beam Push Button Switch on 91 Caprice Classic
I was having a problem with the swith that pulled back to turn on the high beam because a plastic piece that held the rod cracked. I want to rewire the highbeams from the stock push button under the dash behind the steering columb to a new push button that i would like to mount in with the dimmer switch and headlight switch. The problem is there are four wires connected to the stock switch and i believe two are for the headlights since I unplugged the connector and only my corner lights lit up until i plugged the connector back in. The connector has 2 light green wires, 1 that is thicker than the other, a yellow wire, and a salmon wire. Which wires do I need just for the high beams? Any information is greatly appreciated.
Old 08-02-2005, 11:37 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: High Beam Push Button Switch on 91 Caprice Classic
If the 91 panel is like the earlier i might be able to help.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 10-18-2007, 08:37 PM
518Caprice91 518Caprice91 is offline
I can't switch my high beams on either using the stick on the column. What's this "under the dash" switch you're talking about though?
Old 10-18-2007, 09:05 PM
GreyGoose006 GreyGoose006 is offline
i dont know, but this is three years old.
Old 10-18-2007, 09:34 PM
mike561 mike561 is offline
this thread will be closed cause it is too old, just make a new one
2006 Chevy Cobalt LS
Old 10-18-2007, 09:55 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
You are correct sir!
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
The Following User Says Thank You to '97ventureowner For This Useful Post:
aaraiza (01-08-2015)
Closed Thread
