Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 01-03-2004, 07:05 PM
dmacfar dmacfar is offline
ABS or actuator won't turn off
The ABS indicator light came on in my '94 J30 today. When I turned off the ignition (and removed the key) either the ABS unit or the actuator is still running! Has anyone had this problem or have any ideas on what I can do to get it to turn off? I'm concerned about it draining the battery and my service shop isn't open until Monday.
Old 01-03-2004, 07:12 PM
I googled this and found the answer! Should anyone else need to know how to fix this, here is the link:
http://www.infinitihelp.com/Infiniti/FAQ/Brakes/abs.htm
Old 01-07-2004, 07:03 PM
ook ook is offline
Re: ABS or actuator won't turn off
if you haven't already fixed it...here is a temporary fix...
in your ABS relay box is two fuses...
normally, only one is causing the problem, so pull each of them out and see which one is the culprit
it should shut off the noise when you pull the right one
it is recommended to replace these at the same time though
NOTE: your brakes will still work just fine, HOWEVER, you do lose the anti-lock function of your brakes. i.e. you now just have disc brakes.
AND the annoying red light will stay on until you replace the fuses
Old 04-10-2004, 01:43 PM
infinman infinman is offline
In the abs relay box you'll find two relays.Replace both these relays and problem of abs actuator running with key off will go away.
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
1997 Saturn Won't Start & Coolant Sensor light won't turn off. autumnsunn SC/SL/SW 7 01-10-2006 05:27 PM
ABS Light won't turn off bet01 Integra 6 05-15-2005 06:57 PM
94 pontiac Grand AM- ABS light won't shut off and inside lights won't shut off ACWweasel Grand AM 4 02-26-2005 03:46 AM
ABS light won't turn off taurus blues Taurus | Taurus Wagon 4 10-10-2004 09:48 PM
