Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-11-2005, 04:38 AM
bet01 bet01 is offline
Lightbulb ABS Light won't turn off
I have a 92 integra gs My ABS light wont turn off when I start the engine.... what can I do to fix this problem ........need Help!!!!!!!!
Old 05-11-2005, 11:55 AM
97integrals's Avatar
97integrals 97integrals is offline
Re: ABS Light won't turn off
Pull the code, then fix the problem!
Old 05-12-2005, 12:47 AM
What do you mean? Pull the fuse
Old 05-12-2005, 01:43 AM
Re: Re: ABS Light won't turn off
Pull the trouble code not the fuse. I can't help you unless you pull the trouble code and find out what the problem is. Go buy a Haynes manual from the auto parts store it will tell you how to obtain the ABS trouble codes.
Old 05-13-2005, 05:07 PM
Re: Re: Re: ABS Light won't turn off
This is what the code was telling me
Fail-safe relay
(open,short)
How can I fix this
Old 05-15-2005, 04:21 PM
96IntegraLS 96IntegraLS is offline
It's probably more complicated than this, but when my light was on, It was just because the wire had come loose from the battery. I doubt that's the problem but it's always worth checking.
Old 05-15-2005, 06:57 PM
ok thanks for you're time.... I'll give it a try
