Old 10-30-2003, 11:18 AM
taurus blues taurus blues is offline
Question ABS light won't turn off
Any ideas on how to turn off the ABS light on the dash?
It that seems to stay on, sometimes it goes off. I had the brakes serviced the guy told me the brakes are fine and I should take it to the dealer to get them to fix the light. I need to get this car inspected and they won't pass it if the light is on.
Old 10-31-2003, 04:45 AM
bustedratchet bustedratchet is offline
Re: ABS light won't turn off
Other than taking out the bulb. You'll need to have someone pull codes to see why the light is on.
Old 10-31-2003, 12:33 PM
XRoll2000's Avatar
XRoll2000 XRoll2000 is offline
Send a message via AIM to XRoll2000
most likely, one or more of ur ABS sensors needs replacing, pull the abs codes and see what shows up.
SHO Facts
Old 11-02-2003, 03:19 PM
crimp crimp is offline
Re: Re: ABS light won't turn off
My 96 Taurus did this and I found a blown 30 amp fuse for the anti-lock system in the fuse box located under the hood.
After replacing the fuse the light went out and the anti-locks have been working for over several years now without that problem.
I don't know why the fuse blew though.
Good Luck,
Old 10-10-2004, 09:48 PM
jc glass jc glass is offline
using a digital voltmeter(to 3 decimal points)set to milivolts, you can read the voltage change across the terminals of each wheel sensor at the disconnected connector when you rotate wheel
(you have to know what you are doing)
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
Door light and dome light won't turn off Madstone Tercel 0 10-12-2007 12:34 AM
1997 Saturn Won't Start & Coolant Sensor light won't turn off. autumnsunn SC/SL/SW 7 01-10-2006 05:27 PM
ABS Light won't turn off bet01 Integra 6 05-15-2005 06:57 PM
94 pontiac Grand AM- ABS light won't shut off and inside lights won't shut off ACWweasel Grand AM 4 02-26-2005 03:46 AM
