Old 01-03-2004, 05:21 PM
kahuna123_2000 kahuna123_2000 is offline
Unhappy catalyst effiecency
The code I was looking for was 72 = means catalyst effiecency below level. Now i need to know what that means and how can I take care of it? Thank you in advance!!!
Old 01-03-2004, 08:20 PM
gforster gforster is offline
Re: catalyst effiecency
Is the engine running well? If it is then you may have a burned out catalytic convertor. How does the exhaust smell? How many kms since both O2 sensors replaced?
Old 01-03-2004, 10:44 PM
Engine runs fine...No change in smell of exhaust...I dont think I eve changed a O2 sensor because I dont even know where it is.....Do you think this is serious? Thanks for your reply
Old 01-04-2004, 10:37 AM
Here's the possible causes reight from Chrysler:
- Catalytic convertor failure
- Exhaust leak upstream of convertor
- Conaminated fuel
- Mechanical Engine problem
Also if only 1 sensor was ever replaced, it may set off this code. Always replace both at same time. Ebgine mechanical problem means oil burning. If that's the case the engine has clogged the convertor with oil deposits. Fix engine and replace convertor. The only way I can see this is if it's a 3.0. As to the seriousnes of this code it's going to effect your fuel economy quite a bit.
Old 01-05-2004, 03:35 PM
Thanks will check on it
Catalyst 1/1 Efficiency Failure shazbot Neon | Plymouth Neon 3 11-12-2005 07:25 PM
most fuel effiecent crx pika '88 - '91 Civic | CRX | Wagon | Shuttlee 4 01-17-2005 08:57 PM
catalyst - EURO2 dot Engineering/ Technical 0 07-14-2003 02:42 PM
320CE Catalyst weisdaclick General Discussion 1 03-03-2002 01:44 AM
Catalyst Removal gtfury Engine 15 01-09-2002 06:48 PM
