Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 07-10-2003, 01:54 AM
shazbot shazbot is offline
Unhappy Catalyst 1/1 Efficiency Failure
I'm getting engine code P0420 "CATALYST 1/1 EFFICIENCY FAILURE " can anyone tell me what could be causing this? I was thinking I might need a new catalytic converter... the symptoms are lots of stuttering whenever I take off from a stand still to the point where the car won't even move until I floor it out of frustration.. gets even worse with AC on.. the car is a 2k base model. I replaced plugs an wires, helped a bit, but a week later it returned in full force. Any help would be greatly appreciated!
Old 11-12-2005, 06:40 PM
boostinfd boostinfd is offline
Re: Catalyst 1/1 Efficiency Failure
i got the same code... what was the problem?
Old 11-12-2005, 08:16 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: Catalyst 1/1 Efficiency Failure
It could be either your O2 sensor or a bad catalytic converter.
The computer is expecting a bigger difference between the upstream and downstream sensors. It's not seeing that, therefore it is presuming the cat is failing.
possible causes:
-intermittent condition
-visually inspect the cat converter
-exhaust leak
-engine mechanical condition
-aging o2 sensor
-cat converter
Old 11-12-2005, 08:25 PM
mobil_12 mobil_12 is offline
The computer on your car monitors the front and rear oxygen sensors for cataylist effiency. If the front sensor is switching fast and the rear is switching slow, the cat is working. If the rear sensor is switching just as fast as the front then the cat is not working.
You could have a bad cat. Or you could have another problem that is causing the sensors to act alike tricking the computer in to a PO420.
If you are having drivability issues also, that is my bet. You could have a vacuum leak causing the computer to add too much fuel trying to compensate for sensors showing lean. You could have an injector sticking open or closed causing a misfire. You could have an ignition problem or even a bad cylinder.
All of these will cause false readings and PO420. Or you could just have a bad cat. Check the basics first. They can save you time and money.
"The Constitution shall never be construed...to prevent the people of the United States who are peaceable citizens from keeping their own arms."
-Samuel Adams, 1786
96 Dodge Van 3500 Automatic Transmission Failure vince2010 Ram Van 7 01-14-2013 04:12 AM
How can forced induction increase engine efficiency? caffeineaholic Engineering/ Technical 4 07-17-2010 02:41 AM
Rover Metro 1.1 Radio bad connection danny Israel General Discussion 0 07-09-2009 12:20 PM
cat efficiency failure code please help????? truck150 Grand Prix 4 12-12-2005 09:40 PM
1998 Suburban w/ catalyst efficiency failure the_zogs C/K 2 01-03-2004 07:59 PM
