Old 01-03-2004, 04:22 PM
jaabickford's Avatar
jaabickford jaabickford is offline
Send a message via MSN to jaabickford
98 mustang will not start when the engine is at operating temp...help
Hey. Like the title says my 98 stang will not start when the engine is hot. It starts perfectly when the engine is cold. When the engine is at normal operating temp the starter cranks like normal but the engine will not catch. If i give it a little gas while cranking it the engine will start until i take my foot off the gas then it shuts down. after i leave the car for about and hour it will start. I have new plugs, wires, alternator, fuel filter, air filter and my last oil change was three weeks ago. the battery holds a good 12.6v, I had the timing fixed in june. I jumped the fuel pump relay and there is good pressure up to the fuel filter. any direction from you guys would be great....thanks JASON
Old 01-03-2004, 08:26 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
have cylinder leakage (blowby) and compression tests done. it could be that your piston rings are not sealing correctly at op. temp, preventing good compression. i'd say that it's most likely a problem with your head gaskets or piston rings.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-20-2012, 04:02 PM
e40water12 e40water12 is offline
Re: 98 mustang will not start when the engine is at operating temp...help
Sounds like a ignition coil problem.
2003 Alero will not start, only service engine light comes on with key turned to ACC DelbertJay Alero 2 02-20-2012 04:05 PM
2000 Kia Sportage WILL NOT start when it is cold outside..HELP!!! jen0596 Sportage 0 12-15-2008 11:57 AM
96 police vic will not start. Checked the fuel pump etc... Help please klein444 Crown Victoria 8 09-23-2006 08:04 PM
My car will not start when the engine is hot........H...E...L...P!!!!! jaabickford '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-09-2005 06:05 PM
