Old 01-03-2004, 05:01 PM
jaabickford's Avatar
jaabickford jaabickford is offline
Send a message via MSN to jaabickford
My car will not start when the engine is hot........H...E...L...P!!!!!
Hey. Like the title says my 98 civic will not start when the engine is hot. It starts perfectly when the engine is cold. When the engine is at normal operating temp the starter cranks like normal but the engine will not catch. If i give it a little gas while cranking it the engine will start until i take my foot off the gas then it shuts down. after i leave the car for about and hour it will start. I have new plugs, wires, alternator, fuel filter, air filter and my last oil change was three weeks ago. the battery holds a good 12.6v, I had the timing fixed in june. I jumped the fuel pump relay and there is good pressure up to the fuel filter. any direction from you guys would be great....thanks JASON
Old 03-09-2005, 08:22 AM
cmlamb2vx cmlamb2vx is offline
Re: My car will not start when the engine is hot........H...E...L...P!!!!!
I believe your problem is probably the main relay which is under the dash on the driver's side. This controls the fuel pump among other things. Apparently the soldering on these parts weakens with age (heating/cooling cycles) and usually only causes the non-start problem when hot. Mine did the same thing last year and after researching the problem on the web, decided that it was the main relay. Have not had any problems since replacing. Do a google search for 'Honda main relay bad' and you'll find all kinds of info.
Old 03-09-2005, 07:05 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
check cap, rotor, coil, and spark plug gap.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
2003 Alero will not start, only service engine light comes on with key turned to ACC DelbertJay Alero 2 02-20-2012 05:05 PM
98 mustang will not start when the engine is at operating temp...help jaabickford Mustang Talk 2 02-20-2012 05:02 PM
93 Honda Accord will not start when interior is hot. streisel Automotive News Desk 5 01-14-2006 01:07 AM
93 Crown Vic will not start when hot e3jake Crown Victoria 1 06-09-2004 09:51 PM
98 626 will not start when engine hot.....HELP jaabickford 626/Capella/Capella Wagon 3 01-22-2004 07:21 PM
