Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-16-2003, 10:32 PM
jaabickford's Avatar
jaabickford jaabickford is offline
Send a message via MSN to jaabickford
98 626 will not start when engine hot.....HELP
my 98 626 newest problem is that it will not start when hot. when the engine is cool it starts with no problem. once the engine heats up, if i turn it off and try to restart the engine will crank but it will not catch. If i give it a little gas while turning the key it starts and runs until i take my foot off the pedal. I had the fuel pump checked and its fine, the timing was my last problem and $1000+ later i have new hardware down there. the alternator went before that so the new one is less than 8 months old. New battery, belts, plugs and wires. the coil pack also checked out o.k. the fine folks at my local mazda dealer are also stumped. If anyone has any ideas can you please help.
Old 01-19-2004, 09:51 AM
wayne1ca wayne1ca is offline
Re: 98 626 will not start when engine hot.....HELP
I have the same problem with my daughters 2000. Doesn't happen all the time. The idle is so low that it doesn't want to run. Tried to troubleshoot yesterday but, of course, would not show it ugly head.
Old 01-22-2004, 11:40 AM
Jpit Jpit is offline
You may try checking the engine coolant temperature(ECT) sensor. When the engine is hot just disconnect the connector from the ECT and measure the resistance of the sensor with a meter. Should be around 3.5K - 4.5 K ohms. When it cools down the resistance will rise to above 15k ohms and maybe even higher. If it doesn't checkout you may want to replace it. They are about $15 at Autozone. Very easy to do yourself. It's the sensor that sits on the block within 2 inches of the oil cap on my '97 4 cylinder. It just unscrews with a socket. You won't lose much coolant so you don't even have to drain the coolant down.
Old 01-22-2004, 06:21 PM
Thanks, I will check it and let you know how it works out.
98 mustang will not start when the engine is at operating temp...help jaabickford Mustang Talk 2 02-20-2012 04:02 PM
00 f-150 not starting when engine hot. ditchbug F Series 0 05-11-2009 11:12 AM
Will not start when engine is warm jnp59 Camaro Discussions 3 08-09-2006 01:31 PM
My car will not start when the engine is hot........H...E...L...P!!!!! jaabickford '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-09-2005 06:05 PM
93 Crown Vic will not start when hot e3jake Crown Victoria 1 06-09-2004 08:51 PM
