Old 01-02-2004, 02:46 PM
aradran aradran is offline
Question SIMPLE car audio question
Quick question for a car audio install newbie:
I have an '02 Hyundai Accent to which I want to add a CD-changer using an FM modulator. I understand the Antenna wiring. There are three other wires coming out of the box: a ground, a permanent live, and an ingnition live. How do I power these lines? cut into the harness? go in with the fuse box?
I've searched online for the answer to this question but it's glossed over every where. Must be to simple to say out loud....
Thanks
Bren
Old 01-02-2004, 04:32 PM
xekrubx's Avatar
xekrubx xekrubx is offline
Re: SIMPLE car audio question
well you could dig into the back of your radio and find out which wires are what and use a permanent and ignition from there and just ground the unit to the body where there is NO PAINT. or if you dont like that idea the only other thing i can think of is going to the fuse box and finding a constant and ignition power source with a meter. both ways would require you to run wires to the trunk
(or where ever you have the changer mounted)
Old 01-02-2004, 07:01 PM
Re: Re: SIMPLE car audio question
My question is, how do I attach the wire from the modulator to the wire coming out of the back of the radio? ( or rather the wire going from the car to the radio? Do I: cut open insulation and wrap the modulator wire around the bare wire? do I cut the permanent live and put all three ends in a cap? is there an adaptor that plugs into an empty fuse slot that I attach the modulator wire to?
see my question is more mechanical.
Thanks for the help.
Bren
Old 01-03-2004, 05:34 PM
Re: Re: Re: SIMPLE car audio question
no takers?
Old 01-03-2004, 07:24 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Sorry, not much experience with a cd changer or trying to put one on an FM modulator, would love to help though.
www.cloudcity.deviantart.com
Old 01-03-2004, 11:15 PM
lewdaka03 lewdaka03 is offline
JUS guy a head unit and install it............overall its gonna be better
Old 01-04-2004, 11:13 AM
well, I'm sure it is, but I had no intention of upgrading my system at all, nor do I want to spend the money. The CD-changer was a Christmas Gift.
Bren
Car Audio Question Matt_Kot Car Audio 19 08-09-2004 07:40 PM
seriously off topic car audio question maxassassin '88 - '91 Civic | CRX | Wagon | Shuttlee 4 07-25-2004 03:26 AM
Car Audio Question werm '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 05-26-2004 12:29 PM
Random Mix of Car Audio Questions. B-radScottyT Car Audio 7 01-29-2004 07:11 PM
Help! car audio question Scott 02 Car Audio 12 04-29-2003 03:08 PM
