Old 01-02-2004, 09:55 AM
alphalanos alphalanos is offline
Battery Replacement
Im thinking of getting an Optima battery. im guessing all that has to be done is
1 remove old batt.
2 wait a minute or so to reset ECU (i recently put in a high flow filter w/o resetting)
3 put in new one
4 reconnect terminals
anything else, especially something i could clean the terminals with or put something on them to prevent corrosion?
96 EJ6. Future home of boosted B18C1.
Old 01-02-2004, 09:59 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: Battery Replacement
get a battery relocater kit and put the battery in the truck/hatch.
with the optima, you don't have to worry about gasses, and when it's inside, there is little to no corrosion.
Mustangs are nice, but I'd rather have one of these...
Old 01-05-2004, 02:57 PM
SaabJohan SaabJohan is offline
The ECU will loose all information as fast as the battery is disconnected. This should always be avoided if possible.
Old 01-05-2004, 03:12 PM
why is that?
wouldn't the ECU get all that info back when you start the car up again?
Toyota Prius Battery Replacement isearch100 Prius 2 07-11-2013 02:53 AM
2005 Solara Battery Replacement Tips... Intuit Solara 3 04-15-2010 08:05 PM
Need Help...1987 Cooper Battery Replaced with a '96 Corolla battery possible? StunnaX5 Mini 1 | Cooper | Countryman 0 08-24-2008 04:26 PM
Battery replacement jerseyguy 5 Series 3 06-01-2004 09:40 AM
Battery replacement for Diablo ChristAlmighty Diablo 4 02-23-2003 11:59 PM
