Old 01-02-2004, 07:31 AM
Tom Lindsey Tom Lindsey is offline
turn signal suddenly stopped working
I just installed a remote starter on this vehicle following all the proper procedures, including using a test light on all circuits prior to wire tapping. Upon completion everything worked fine until I tried to turn on the turn signals. What to do? No blown fuses or anything else obvious.
Old 01-02-2004, 10:05 PM
busboy4 busboy4 is offline
signal
Hi Tom,
not to be flippant, but did you check the bulbs? No filament, no signal. Not likely for them both to fail together under normal situation, but after doing some electrical work you never know (I spent the whole day trying to find a perceived electrical problem on my new exterior house lighting only to find that all the bulbs in the fixture fried at the same time).Do the other items on the multifunction switch work?, ie washer, wipers, high beam etc? Do the turn signal lamps illuminate, but no flash?-there should be a flash unit that produces the on/off.
Let me know what you find. I'll take a look at my manual tomorrow. It's late.
Best of luck.
Old 01-20-2005, 01:51 AM
Michael234 Michael234 is offline
Unhappy Am having same problem after battery went.
Have checked all the obvious lights and fuses.Seems like the function lever is not working.Hope it is.Will be taking it in cause I am not the person to find the problem in the column.Something has blown,but where ????
turn signal lights not working x3mtm Durango 4 01-11-2010 12:49 PM
Blower in 1991 Mercury Cougar Stopped Working nadine1961 Cougar 0 09-15-2009 03:59 PM
Help, 97 Grand Marquis the flashers and turn signal have stopped working karen402 Grand Marquis 4 07-01-2006 09:49 AM
If my remote suddenly stops working do I need a battery? Bigwashe Montana/Montana SV6 1 07-28-2004 08:06 PM
Turn Signal indicators stopped working sanxxx Intrepid 1 02-03-2004 07:53 AM
