Old 12-31-2003, 11:13 AM
4beatg8 4beatg8 is offline
EGR Flow Insufficient
Check engine light stays on continuously on my 1996 Ford Conversion Van. Had the codes pulled and the code was P0 401 - EGR Flow Insufficient. Where is the EGR valve located on this vehicle? Also, what else you I check before replacing the EGR valve?
Old 01-01-2004, 07:42 AM
gearhear gearhear is offline
Re: EGR Flow Insufficient
this is a very common problem on fords. it is probably not the valve giving you a problem. you should remove the throttle body and clean out the egr passages with throtle body cleaner and some sort of small brush. make sure all of the air passages in it are clean
Old 01-03-2004, 05:44 PM
pete54ford pete54ford is offline
Send a message via Yahoo to pete54ford
My understanding and experience is that if the EGR valve is messed up, ya might as well clean or replace the idle air controll motor...I can tell ya where both are on a Ford F150, but on a van I must take a zero. Good luck!!
The cursed P0401 EGR Flow Insufficient chevyrulez1 Rodeo | Passport | MU 1 11-07-2010 08:32 PM
egr flow insufficient ashah000 Off-Topic 7 08-17-2005 06:34 PM
EGR flow insufficience (Windstar) lteehq Windstar 5 11-02-2004 08:05 AM
Code P0401 - Egr Flow Insufficient orozco_joe Malibu 1 09-14-2004 05:31 AM
egr flow insufficient jwebb37 Windstar 9 11-23-2003 08:04 PM
