Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-30-2003, 05:42 PM
Flormat Flormat is offline
Replacing U-joint in 1500 4X4- please help
I'm trying to replace the rear u-joint in my 2000 Ram 1500. The retaining clips holding the u-joint caps were rusted in place and 2 of them broke off so half of the clip is stuck. I've tried liquid wrence but they still won't come out- any advise on getting them out? Also where it bolts up to the differential seems to be stuck. After removing the bolts and giving it a couple of whacks it won't budge- any advise on that? Thanks for any help.
Old 01-14-2004, 08:43 PM
silky4u's Avatar
silky4u silky4u is offline
Re: Replacing U-joint in 1500 4X4- please help
Where it bolts up to the differential? That normally wont move unless the tires are moving. Are you hitting the yoke where the u-joint sets in? Maybe i am seeing this differently than you, but you can just go and get a new u-joint and it should come with new retaining clips.
I hate ALL people!
Old 01-15-2004, 10:36 PM
speedindevil's Avatar
speedindevil speedindevil is offline
Send a message via AIM to speedindevil Send a message via Yahoo to speedindevil
I think I know what you mean, I had a similar problem on my truck, for the ones where the clips are broken, you can either use a small punch after they have been soaked in liquid wrench(tap it with a hammer a few times to get the liquid wrench to work) and try to make it rotate, then try to pry it out with a pick or an even smaller punch, otherwise, try to shatter it with the puch piece by piece. As far as the rear connection, you may have to do the same, pry it out with a punch, just watch your face when it finally falls
"If you have tried to do something and failed, you are vastly better off than if you had tried to do nothing and succeded"-----(someone famous)-----
2000 Silverado 5.3L 1500 4x4 Silverado_Dude Silverado 21 11-24-2009 10:02 PM
2004 Dodge 1500 4x4 Quad help needed dss56 Ram Pickup | Ram SRT10 3 10-02-2009 04:56 PM
NEED HELP!!! Dodge Ram Slipping Transmission jon2dope1987 Ram Pickup | Ram SRT10 2 09-04-2009 01:58 AM
1997 ram 1500 vibration please help RamPower Ram Pickup | Ram SRT10 7 10-14-2004 07:43 PM
RAM 1500 problems...please help tjstepan Ram Pickup | Ram SRT10 1 08-29-2004 08:35 PM
