Old 12-30-2003, 03:15 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Car now idles like a lawnmower.... ????
I have been recently having problem with the hesitation around 3k rpm and up, replaced cap and rotor, wires, plugs, no difference...then just like 2 days ago my car started running hot. I replaced the thermostat, and it seemed to fix the temp problem-till i get on it then the temp will go up for a sec, then after i let off it will go back down, it never used to do that..also when the temperature problem started happening, the engine runs fine when i give it gas, but when it idles it puts like it's got a cam in it or somethin-lower idle speed and it instead of purring it's like blub blub blub blub blub like about 4 pulses a second...WTF!? And also when it does that white misty smoke like steam come out my exaust...someone said I might have blown my head gasket? any idea? i'm so sick of this SHIT
thanks
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 12-30-2003, 03:30 PM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
its most likly your head gasket. i had the same problem till i got stuck and had to bump start it just to get it home.
the head gasket is really easy and cheap to replace i think felpro has one for like 25$. if you dont have the money to get the head resurfaced make sure you clean it off real good with a razor blade. make sure you change you distributor o-ring too.
Old 12-30-2003, 06:29 PM
quiXilver's Avatar
Re: Car now idles like a lawnmower.... ????
well i just got my distributor in today, so maybe I should wait till i replace the head gasket to put the dizzy in. and i'm gonna replace the valve seals too when i take the head off, make sure i have a nice running engine, 'cause one of my plugs had oil on it when i took it out the last time.
B18A
Old 12-30-2003, 08:32 PM
88CRX's Avatar
88CRX 88CRX is offline
99% sure its your headgasket.
and to make it 100% sure..... look at your oil. pull the dipstick, is there a milky white on it? what about under the oil cap?
gauranteed there probably is?
are you loosing coolant?
btw, when you change the head gasket check the head to make sure it hasnt warped at all, cause if it has and you dont get it fixed it will continue leaking.
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 12-31-2003, 12:58 AM
quiXilver's Avatar
well son of a bitch, yes, i'm loosing coolant, yes there is a nasty white goo stuck under the oil cap...well looks like i need a head gasket.
88CRX you are the man and everyone else that's helped
B18A
Old 12-31-2003, 11:19 AM
88CRX's Avatar
time for a zc?
zc powa
short ram intake
dc sports header
h/r race springs
Old 12-31-2003, 02:31 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
If you are keeping the DX, time for a upgrade to a metallic 92+ headgasket Higher compression=more HP.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 12-31-2003, 06:42 PM
quiXilver's Avatar
well shit I just went out and bought one-how do I know what gasket to get?
B18A
Old 12-31-2003, 10:39 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
soudns like a lawnmower...lol....get rid your exhaust...solves most imports problems
Old 01-01-2004, 01:22 AM
quiXilver's Avatar
Re: Re: Car now idles like a lawnmower.... ????
actually my exaust sounds really good when it's running right, now how bout reading the post instead of just finding someone to diss on
B18A
Old 01-01-2004, 03:08 PM
Depends on how thin you want it, the d16y8 is supposibly thinner than the d16z6 headgasket. They are both metallic. Pretty much any SOHC head gaskets 88-00 will work. If you wanna up your compression a little, get a z6 gasket, if you want it higher, get a y8.
-2000 Civic Hatch
-1998 Lexus SC300
Old 01-02-2004, 01:14 AM
CR50HC CR50HC is offline
Will these head gaskets fit the D15B2 motor as well?
Old 01-02-2004, 01:23 AM
Yes
-2000 Civic Hatch
-1998 Lexus SC300
Does your car idle like it should? SiZ '88 - '91 Civic | CRX | Wagon | Shuttlee 34 01-05-2010 01:25 PM
changed plugs, wires, and coils, now runs like crap raziel200 Rendezvous 3 01-11-2009 07:19 PM
Now I like these guys 360Deluxe COMPLETELY off-topic 1 06-30-2008 09:12 PM
help i put my shock togetherand now its like a inch to long smokeymicpot '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-17-2004 02:58 AM
86 350tpi idling like crap????? Davecamaro86 Camaro Discussions 8 01-26-2004 12:20 AM
