Old 12-29-2003, 03:29 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
What next?
Ok I got bout 200 to play with now here are a few ideas i thought you guys could help me with or put up some of your own. MPFI (no one evers got it though) Rear disks (same) Spoon rear upper strut bar. Rear Cargo cover speaker (yet again) spend on me gheto turbo kit stuff like VAFC i/c piping. save up for ZC CF hood or my last idea save up for swap but not sure what swap yet.
Old 12-29-2003, 04:00 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: What next?
Save the money on the spoon bar, and get something just as good, but cheaper.
Rear speaker mounts can be purchased at the dealer for like $40
Old 12-29-2003, 04:05 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: What next?
Hows your suspention setup?
Check out my car here My 91 Hatch
Old 12-29-2003, 04:14 PM
Ace$nyper's Avatar
Banned
Ok Kris i'll take a peek at the Skunk2 ive been happy with them just want to see what it looks like IRL before I get it. Also what about the rear speakers cause i've asked at my local dealer cause they say the don't have them anymore.
Dumped I have skunk2 coilovers Koni yellows ES bushin kit Trust upper front strut bar. Skunk2 rear lower tie bar.thats all me think.
Old 12-29-2003, 04:22 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: What next?
i would go with MPFI or the rear disc brakes
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 12-29-2003, 05:29 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
or you can buy my ex knuckles....ie "big brakes".
There's nary an animal alive that can outrun a greased Scotsman!
Old 12-29-2003, 08:56 PM
Ace$nyper's Avatar
Banned
ok thx all for the ideas i'm down to bout 130 now i just bought some new toys for my makarov. Anyone got more ideas now i'm leaning to the Skunk2 rear upper bar.
Old 12-29-2003, 10:02 PM
slave slave is offline
BANNED
Re: What next?
Fuel Baby!!!!!
JDM IS NOT LHD
My other car's a Porsche, but today I'm in a hurry.
Old 12-29-2003, 10:50 PM
BullShifter's Avatar
Re: What next?
How about a rear sway bar
Old 12-30-2003, 01:02 AM
Re: What next?
I agree with Jackasssi, sway bar.
Old 12-30-2003, 09:57 AM
alexdog69's Avatar
alexdog69 alexdog69 is offline
Re: What next?
Suspension Techniques Rear Sway Bar
Old 12-30-2003, 12:11 PM
Ace$nyper's Avatar
Banned
ok sounds good don't i need SI rear control arms though? woot time to hit exhaust with hammer to fit it too lol.
Old 12-30-2003, 12:35 PM
Re: What next?
No, the ST rear mounts to the lower shock mounts unlike the Si bar that mounts to special holes in the LCA's. Lower rear tie is a good idea with a large rear bar.
Jeg's has the rear only for $100 or so
The open hole on the top of LCA is for the stock rear sway. For the ST rear install you must remove the lower shock bolt & bust off the welded nut. Then install a new bolt in the opposite direction of stock, install bracket to bolts. The connects to the adjustable bracket. For the other brackets, those mount under the rear tow hooks with new bolts. Very simple install & adjustments.
Old 12-30-2003, 01:53 PM
Ace$nyper's Avatar
Banned
ok cool i'm looking it at it in my jegs right now. 3 more things i gotta bug you with. 1 will this clear my exhaust 2 1/4 inch 5 zigen (bend like stock). 2 says only for models with front sway mine STD has none is this a problem? 3 this one is extra dumb but just wanta double check. If i order some aftermarket SPC LCAs (only like 2lbs) will this cause any probs? thanks a bunch!
Old 12-30-2003, 02:56 PM
Re: What next?
Exhaust pipe clearance shouldn't be a problem
Muffler may be an issue, My stock muffler/heat shield rub once in a while.
I'm not sure why it says to use only with stock front sway, but my guess would be the induced oversteer. On a FWD with no front sway & large/tight rear sway, the car can become very unstable at high speeds. Usually resulting in snap oversteer, which takes a highly skilled driver to recover control - most of the time your along for the ride. No front sway & large sway is a good autocross set-up, I suggest learning the new feel of your car before taking some high speed turns.
The LCA won't cause any problems but really don't do much besides weight savings & looks. The bushings are better than stock which helps in handling.
tranny rebuilt...what next in future? mgcatthew Accord/TSX/Accord Hybrid 5 04-24-2002 03:50 PM
New G20, but whats next- help? taurus252 General 4 02-26-2002 01:41 PM
b18a whats next hb7 '71-'87 Civic | CRX 4 02-03-2002 07:46 AM
What next for my suspension? hondacsi Tires and Wheels 10 01-22-2002 05:08 PM
Bought my first G20 today!!!....what next?? northwestrally General 7 05-03-2001 12:31 AM
