Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 12-28-2003, 03:52 PM
RaulLince RaulLince is offline
coolant boiling out of overflow
well as ive stated before on another thread, ive got problems. Today i took the truck out for a test run with barsstop leak in the system. when i got home (maybe 30 minute drive) i could hear coolant boiling under the hood. Popped it and voila, coolant was belching out of the overflow. Now, i have no white smoke, so is it fair to say that it is the head gasket still? I'm too green to know the difference. My gut tells me its something much worse. ANy help? Raul
Old 01-03-2004, 01:18 AM
themazdaguy202 themazdaguy202 is offline
ur answer
Yuppers. U've blown the head gasket, and at all worse, the head itself is cracked. U dont need white smoke to do this.
Ok, the first test is, run the engine for a short amount of time, does the coolant piss out, and is it COLD or HOT, if its cold, its the head or head gasket. Next, use a cooling system pressure tester and put the cooling system under pressure. Before this though remove all the sparkplugs. Keep the system at pressure for 5 min or so and then have someone crank the engine while u watch the sparkplug holes. Does coolant come out one of them??? If so pull the head and inspect the head gasket on the cylender(s) which sprayed coolant. Then inspect the head for cracks. If the head gasket is broken somewhere then obiously u just need a new one.
05 Civic Coolant flows to overflow, doesn't come back plmnwater '01-'05 Civic 3 01-25-2011 04:40 PM
coolant boiling foxman18 MR2/MR-S 8 04-09-2005 11:51 PM
00 Blazer Engine coolant boiling over Phix_06 Blazer 1 07-11-2004 08:40 PM
93 blazer overheating, no heat, coolant boiling out of reservoir Help! Feelinbeefy Blazer 1 02-01-2004 01:19 AM
GTP coolant boiling? mariowc Grand Prix 3 07-28-2003 03:55 PM
