Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 04-05-2005, 11:04 PM
foxman18 foxman18 is offline
Unhappy coolant boiling
when i drive my car around and let it warm up and then turn it off i can hear the coolant boiling. i flushed the system and put new coolant into it but that didnt work.
then i did a cylinder leakage test to see if it was the head gasket but they all ranged from 10%-32% leakage. would that cause this problem. if not could anybody give me an idea to what would be the problem
your input will be greatly appreciated
thanks
Old 04-06-2005, 03:45 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: coolant boiling
aparently it's fairly "normal" for the coolant to boil when you shut the engine down. seems sus to me every time i hear it too though...
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 04-06-2005, 08:10 PM
Re: Re: coolant boiling
so wat your saying is that its normal to be able to hear it boil.
Old 04-07-2005, 02:15 PM
NJMR2 NJMR2 is offline
I have the same issue, thought it may be the thermostat going.
Old 04-07-2005, 10:41 PM
Re: coolant boiling
i changed that too but it still does it. but i might have got screwed and got a bad one. do u think i should try changing it again?
Old 04-07-2005, 11:40 PM
BlitzKeg's Avatar
BlitzKeg BlitzKeg is offline
Re: coolant boiling
your coolant system is pressurized. the pressure raises the boiling point or boiling temp. of the coolant.
therefore if your losing a large amount of pressure from a hole in the radiator or a bad head gasket,
you will lower the boiling point(boiling tempature).
and this will eat up alot of coolant.by evaporation.
What I suggest is get a radiator pressure tester.....hook it up and it should hold atleast 8-12psi ......if its not holding pressure than it will leak quickly as your doing the test, enabling you to find your leak.....
its so easy, even a caveman can do it.
Old 04-07-2005, 11:50 PM
BlitzKeg's Avatar
Re: coolant boiling
oh yea high leakage percentage from a leak down test could be bad rings, valve seats, oil cap, carbon deposits, head gasket, there are many variables......when your doing the test you should be able to hear the air leak from the problem. ah shit its late.. got2 crash. gl
Old 04-08-2005, 03:54 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: coolant boiling
Hearing your coolant boil in the engine bay is 100% normal for the turbo MR2.
There is nothing to be concerned about.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 04-09-2005, 11:51 PM
Re: coolant boiling
thanx for all your guys input on the coolant. that definatly makes me feel better. thanx again
-Doug
