Old 12-28-2003, 09:13 AM
mbazid mbazid is offline
Unhappy Is it the Transmission?
Hello
I was hoping someone could give me some advice. I have a 89 Plymouthe voyager. the other day (out of the blue) it started pulling hard to the right and I would here a knocking sound comming from the right front tire. It would do this for about two minutes than stop and run fine than start again. Than just when i was about a block from hame I turned a corner and as i was turning I herd a very loud crunch. I pulled over and killed the engin to take a look. When I got back in and started it and put it in drive it makes a very scarry crunching noise. It makes the same sound in 1st and reverse. I was told that my trans mission is shot. Than I was told it might be the berrings or somthing else.
My mechanic is on vacation. Does anyone have any ideas
Is this a problem with the Transmission??? Jenni75 Caprice 8 02-06-2010 05:16 PM
To what degree does it hurt the transmission with not sufficient transmission oil? lidation Windstar 4 10-05-2007 06:57 AM
Transmission fluid coming out of the transmission stick, Help?? Ferngee 626/Capella/Capella Wagon 2 04-03-2006 01:12 PM
Why can't clutches be placed between the transmission and the differential? 454Casull Engineering/ Technical 7 10-02-2002 01:29 PM
Keeping my hand on the stick ... does it ruin the transmission ??? Help ! DjGurdon Engineering/ Technical 3 05-08-2002 09:11 AM
