Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-05-2010, 07:56 PM
Jenni75 Jenni75 is offline
Exclamation Is this a problem with the Transmission???
94 Caprice 9C1
When put into gear there is a ticking/scraping noise. This does not happen when in Neutral or Park. Could this be the transmission going?
Old 02-05-2010, 09:11 PM
j cAT j cAT is offline
Re: Is this a problem with the Transmission???
Originally Posted by Jenni75 View Post
94 Caprice 9C1
this needs more info ...in gear ok ...what speed ? does this frequency of the noise increase with speed ? engine RPM ? turning left/right....
check tires / brake shields/ worn brake pads...[wear indicators]
Old 02-06-2010, 09:45 AM
Blue Bowtie's Avatar
Registered Offender
If this occurs with the trans in gear while standing still, there might be a converter problem.
As j cAT advised, more detail would be helpful.
Old 02-06-2010, 09:50 AM
mattdarton mattdarton is offline
Never heard a ticking sound from transmission . most ticking sounds come from loose heat shields on the exhaust.
Old 02-06-2010, 10:22 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
A ticking sound could indicate loose torque converter mounting bolts ... or a broken flexplate (which can also scrape).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-06-2010, 11:58 AM
The sound doesnt seem to speed up or slow down with accelleration. Even when idling in gear its just there. When in neutral or park no sound at all. The car is shifting normally as I drive. I checked the transmission fluid and it was fine. The actual only difference in the car is just the added noise that showed up yesterday. The sound does seem to be coming from the drivers side area...but i could be wrong.
Old 02-06-2010, 01:06 PM
If the transmission was ever replaced it is common for the flywheel bolts to be improperly installed ....removal of the flywheel cover and inspect for proper torque of all bolts...
also with this cover removed with the vehicle in gear listen for this noise as the torque converter is there...this may be the issue as well..
One time on a new vehicle it was an improperly installed flywheel cover rattling in gear,,,,
Old 02-06-2010, 03:59 PM
Thanks...What should the flywheel bolts be torqued to?
Old 02-06-2010, 05:16 PM
Registered Offender
http://www.youtube.com/watch?v=EodvVgyB5DE
Flexplate bolts should be 74-75 ft/lb, and torque converter bolts should be 44-45 ft/lb.
Tags
scraping , ticking , transmission
