Old 12-27-2003, 11:50 AM
Docholiday Docholiday is offline
Unhappy Brake Light flashing
Recently, my park brake light on the dash of my '91 K1500 started flashing.....3 short flashes followed by a long flash. It must be a code of somekind. Any ideas anyone??
Old 01-14-2004, 05:37 PM
FghtinIrshNvrDie FghtinIrshNvrDie is offline
Send a message via AIM to FghtinIrshNvrDie
Re: Brake Light flashing
yeah, mine just blinks. I don't think it's a code, but maybe it's a hint to get your brakes checked out. mine are kinda crappy, so I think it may have something to do to it
Old 01-15-2004, 10:17 PM
Blown R1's Avatar
Blown R1 Blown R1 is offline
check your fluid level, if not i doubt its a code. make sure your park brake foot lever isnt loose or partially pushed down.
Blown R1
"gone 240 in the 1/4 @ 6.23"
Old 06-29-2004, 01:11 PM
leadjackal leadjackal is offline
My Brake light is flashing too. It blinks 9 times then pauses and repeats the 9.
It appears to be a code. I have got to get some answers, I drive a lot at night and the darn little thing is getting to me.
flash flash flash flash flash flash flash flash flash
Make it stop.
Old 06-30-2004, 09:37 AM
Brake Light Flashing Code
Blown R1, I am sure you ment well, but
The flashing brake light IS in fact a CODE. I found the following information on a GMC forum.
MESSAGE
my brake light was flashing a code I don't have the codes for the brake system, it was 4, 15 times , then one 3 then back to the 4's? does this make sense to anyone?
thank's LINK
REPLY
Is this happening on the '89 you have listed in your info?
If so you should only have rear wheel anti-lock...according to a Chiltons diagnostic flow chart I have,they say to hook up a TECH 1 or equivalent to check the codes..
OR you can jump the "A" and "H" pins of the ALDL connector under the dash to get the codes by reading the flashing brake light....any how here r the codes:
Code 2: open isolation solenoid or EBCM malfunction
Code 3: open dump solenoid or ECBM malfunction
Code 4: grounded anti-lock pressure valve rest switch
Code 5: excessive dump valve actuations during anti-lock stop
Code 6: erratic speed signal
Code 7: shorted isolation solenoid or ECBM malfunction
Code 8: shorted dump solenoid or ECBM malfunction
Code 9: open or grounded speed signal circuit
Code 10: stop lamp switch circuit
Codes 1, 11 and 12: invalid diagnostic trouble codes
Codes 13, 14 and 15: electric brake control module (ECBM) malfunction
You could also clear the codes by removing the "STOP/HAZARD" fuse for at least 5 sec. and see if it may reset...
I would also suggest that you get a repair manual to verify the above information for yourself, it would also detail the procedures for diagnosing the problem...the components of this system are REPLACE ONLY items, and I would hate for you to waste money if the diagnosis is incorrect and the problem comes back after replacing parts.....Hope this helps..GOOD LUCK
hey , thank's for the info , I'm gonna try it right now.
Thank you again!!!!!!!!! LINK
If you want to check it out for yourself the link is
http://www.gm-trucks.com/forums/ (sign up then search)
the following link is the actual link and it may not work
http://www.gm-trucks.com/forums/inde...hl=brake+light
Old 06-30-2004, 11:14 AM
Thunderbolt Thunderbolt is offline
Is it the parking brake light flashing or the regular brake light ?? If it is the regular brake light then it is indeed a code for the rear antilocks. If it is a parking brake light then it is not a code. From what you describe it is an exact sequence of flashing which tells me it is a code for the antilocks. If it was anything besides the antilocks the light would stay on steady.
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
