Old 12-27-2003, 11:01 AM
cwalker cwalker is offline
Hazard lights wont flash--turn signals do work
My daughter's home from college with her 1998 Taurus. I'd like to fix her hazard lights. I replaced the turn signal flasher and was told by the Ford house that the same flasher works the turn signals and the hazards. Turn signals work (as long as the hazard switch is in the off position), but the hazard lights won't flash. Since the hazard switch does defeat the turn signals, I assume this suggests that the same flasher works both (?). Any ideas?
Old 01-14-2004, 05:10 AM
Thumbs up
The problem ended up being dirt!! in the hazard switch itself.
Old 02-03-2004, 12:35 AM
frag24 frag24 is offline
Hmm
How Did You Know That It Was Dirt???
It Happened To Me Just The Other Day.... I'm Not Sure If It's Too Cold Out Here Reason Y It Mulfunctioned
Old 02-03-2004, 08:50 AM
I took the car to a mechanic, and he diagnosed the dirty switch. I live in West Texas, by the way, and dust gets into everything here.
Old 02-06-2004, 04:36 PM
RJExp RJExp is offline
Re: Hazard lights wont flash--turn signals do work
Your multifunction switch is dieing. The hazard lights will be the first to go, then either the turn signals or the wipers. I had to have mine replaced on my Mark VIII and Exped. and it cost about $180 at the dealer. You may want to have the switch checked at the dealer.
98 EB Exped. 4x4 5.4L
K&N FIPK
Flowmaster 70 Series 3" SOS
Diablo 2 Stage
Power Slot rotors w/ Hawk pads
Edelbrock IAS
Energy Suspesion Bushings
Sylvania Xenarc Headlights
Bridgestone Dueller A/T REVOS
Old 02-09-2004, 09:31 AM
Thanks for the warning about the impending switch failure. I'll be sure and take my daughter's car in the next time she comes home from college. Thanks again.
Old 02-10-2004, 06:35 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
cwalker - you said that a single flasher works the turn signals and hazards, is that the same on the 1996 taurus???? and does anyone know where that flasher is on the car?
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-27-2004, 09:50 AM
Spitzer Spitzer is offline
Send a message via AIM to Spitzer Send a message via MSN to Spitzer
It's Just dirt. I have a '97 LX and my older brother has a '97SHO and that happend to both of use. I just pumped the switch about ten or more times. That fixed it. My brother with the SHO pulled the steering apart to get the switch out and clean it. Mine works fine and with what I did and never has had another problem.
1997 Cutlass Supreme SL Hazard Lights Help fonzie9 Cutlass Series 0 11-26-2010 09:24 PM
Left turn signal/left side hazard lights won't flash djmann02 Accord/TSX/Accord Hybrid 4 11-19-2007 04:03 PM
abs flashes and light/wipers/and turn signal don't work at together customdc Windstar 4 12-12-2005 07:37 PM
parking light out, but turn signal works... 99Zseven C/K 2 03-31-2004 06:41 PM
hazards wont flash - turn signals DONT work 89IROC&RS Taurus | Taurus Wagon 2 02-20-2004 05:28 PM
